What do you make with these?£38 for these: CBN lathe tool inserts. These will cut even hardened tool steel and it's amusing to see sparks and red hot (glowing!) chips coming off when turning in the lathe. CBN is better than diamond in this case because, although slightly softer, it is far more resistant to high temperatures. It's harder than carbide but diamond is the better option for that.
I presume it will be some high precision mechanical parts?
