I actually prefer the look of the Hypervolt at the moment, though I hope you can turn off / down that dodgy light on the front
You can
My nickname is monkey so this is very on brand
It's far more simple that that. Just make a charge port with one hand using your index finger and thumb, then insert your index finger of the other hand to represent the charge cable while maintaining eye contact with the other driver and giving a knowing nod.
I actually prefer the look of the Hypervolt at the moment, though I hope you can turn off / down that dodgy light on the front![]()
I had my Hypervolt 3 installed a couple of weeks ago, cost £1200 in total using a local electrician. My install was tricky also as the consumer unit was a good distance from the front of the property. Standard installers wouldnt touch it but luckilyIt's the Hypervolt 3 that I'm getting installed on Monday, all being well.
Remember to seek out at any grants that you can get for installation, I got £400 which lessens the £1,500 installation cost. Yes, that's is high but it's a tricky install with a garage consumer unit required and more cable than normal.
a local electrician would and did a good job of routing the cable.
Just waiting for the Born VZ to be delivered next week. I wasnt really looking at changing my vehicle but £10k off list price and 7000 free charging miles tempted me!.
Where are such grants available? I've had a look on my local council website but to no availIt's the Hypervolt 3 that I'm getting installed on Monday, all being well.
If you own your own house and live in England there isn’t anything.Where are such grants available? I've had a look on my local council website but to no avail![]()
ZappiRight, last question (hopefully for the forseeable future)
WWOCUKD?
Either:
(A) £1.3k for zappi with my original solar PV installer, or
(B) £1k for wallbox pulsar max installed by eon
Pros of (A):
- compatible with octopus and eon
- my solar PV + battery is insulated and not connected to the charger, so I can export the solar and battery won't discharge to charge the car
Cons of (A):
- expensive
- zappi charging box is massive
Pros of (B):
- cheaper
- pulsar max is small
-compatible with octopus and eon
Cons of (B):
- unit is not blind to my existing solar setup
£300 at 7p/kwh is ~4300kwh, which is A LOT of miles on an EV, but is it worth the £300 just for the peace of mind that the charging circuit is done properly?
(properly = insulated from the PV circuit)
Only available for us dirty renters in England at least. We got £350 off our installWhich grant did you get?
I wasn't aware of any for home chargers for regular people anymore?
Ah, fair enough - don't worryIt was from the Energy Savings Trust and it appears it's for those owning or leasing an EV in rural or remote parts of Scotland. Sorry for getting anyone's hopes up.
Probably won't apply to me as I have a driveway.There is a grant available in England for those with on-street parking - provides EV drivers support towards the costs of the purchase and installation of EV chargepoints at residential properties when also installing a cross-pavement charging solution. Source. Doesn't look like it will help much though.
Hypervolt hope 3 pro is £1049 from octopusZappi
Or hypervolt.
I'm guessing because it's installed by eon (or octopus if i opt for the hypervolt) that they won't do the isolation/ct clamping/whatever needed to isolate the EV from the PV batteriesWhy wouldn’t B be blind to your battery setup but A would be? That determined by the physical wiring than the charger itself unless you have a libi battery.
ah good pointsB doesn’t have integrated cable management so it will look messier than the Zappi.
Edit: don’t forget export rates could change in the future so it might make sense to charge your car from solar again so it would be handy to have that feature.
