CPU Cooler Clearance Issues
22 Jun 2015
South of the north but north of the south.
Currently running a Noctua NH-D15 chromax paired with an RTX 5090 — absolute beast of a CPU cooler. I’ve got the fan curve dialed in so it’s pretty much silent.
Only issue is, the cooler is physically touching the back of my GPU. From what I’ve read online, this shouldn’t impact performance or cause any problems, but I wanted to double-check with the community.
Would this setup be fine long-term, or should I consider swapping to a smaller cooler?
For reference, I’m on a 7800X3D.
(Please note the only PIC I have is when I had my RTX 4070, but same issue exists with reference RTX 5090)
Thanks!
Does the NH-D15 allow you to offset it? Some HSF's do, although not as efficient going against the offset mountings intended direction, in your situation, it would gain you clearance from the GPU.
If you've got some spare thermal paste, it may be worth you seeing if you can flip the mounting 180 degrees. I know the Peerless Assassin and Phantom Spirit offer an offset AM4/5 mounting, to add the spread over the cache IIRC, as I've seen someone test fit it 180 degrees the wrong way.
Hope this helps, if not, I'd personally change coolers - the Thermalright Peerless Assassin 120SE or Phantom Spirit 120SE can be had for very little (OCUK Sell both and other Thermalright HSF's ;)), and I'm sure you could easily sell the NH-D15 and have some change after covering a Thermalright HSF.
I personally wouldn't want any form of heat transfer from the CPU HSF or GPU, nor to risk scratching such an expensive GPU.
Hope this helps!
Hope this helps!
I'm actually already using the Noctua offset bracket which allows for better cooling, however it pushes the cooler down even further to the GPU!
"If you've got some spare thermal paste, it may be worth you seeing if you can flip the mounting 180 degrees. I know the Peerless Assassin and Phantom Spirit offer an offset AM4/5 mounting, to add the spread over the cache IIRC, as I've seen someone test fit it 180 degrees the wrong way."
The above is a solid recommendation, however if I remember rightly it's only the G2 that allows for inversion. The standard version can only be mounted the one way. But I will reinvestigate.
If the above fails I may go down the route of another cooler, as I also don't like how close the two components are to one another, and it's a nightmare whenever I need to take the GPU out. Shame really as I'm a Noctua fan boy at heart!
So does that mean without the offset bracket, it will clear? Or do you mean that's the only way that you can mount it?
Thanks, yeah it's definitely worth checking mate, you might get lucky.
Yeah, you could easily sell your cooler secondhand for the price of a Thermalright and probably a bit of cash left over? Either way, you will gain what you need - checkout the reviews, they match your cooler pretty much, along with any competitor at the time of release. Cant go wrong for the money. The Phantom Spirit has an extra heatpipe, but from what I've seen in reviews, you barely gain much in terms of real world temps, maybe 1-3 degrees if you're lucky IIRC - so if it was me I'd just get the Peerless Assassin 120SE and have some money left over ;):D
I Personally would not be happy with them touching, regardless of if it doesn't transfer heat. It'll still scratch a very expensive GPU.
"So does that mean without the offset bracket, it will clear? Or do you mean that's the only way that you can mount it?"
If I remember rightly it clears without the offset, but by the smallest smallest amount, E.G 0.000001mm. With the offset bracket it 100% touches.
Will have a play round tonight and report back, but I think a new CPU cooler may be on the horizon!
Haha, that offset bracket seems pointless if it's that close either way :P
Yeah, for the sake of sacrificing some paste, it's worth a go ;)
If not, get on the Thermalright train, a search on here for Thermalright, be it air or AIO's. will provide you with all the reassurance you need :)
alternatively and this is what i would most likely probably do [because theres no way im giving up my nhd15 either .... another massive noctua fan boy here lol]
get a riser cable and move the gpu a bit even just one pci slot or something......... just a thought move it just enough so its not touching or move it entirely if not anything to not have to lose my noctua cooler
Or to throw a curveball, how about switching to an AIO?
The current G.O.A.T. is the Arctic Liquid Freezer III Pro 320mm or 420mm if your case allows for the thicker/taller requirements of the Arctic, or go for a Thermalright AIO? - Again just search on the forum and you'll find nothing but good things to say about either brand's options!
I'm pretty sure you can buy either for the price of a decent riser cable, or at worst not be far off? At that point you would be mad not to ditch the NHD15...
I had another look at the cooler placement today and wanted to provide some further images, to see what you think. Upon further inspection it’s still really close but from what I can see does not actually appear to be touching?
Thanks again!
It's fine.
Just get a piece of paper if it slides between the two, it's ok.
Saves selling off a perfectly good HSF just to get a similar one. It's not like you have a crappy stock HSF
It's fine.
The paper fits! That's genuinely such a good test, can't believe I didn't think of that.
Thank you.
What are the temps like ?
If the CPU and GPU are at acceptable temps under load then your good
Temps seem fine to me.
  • GPU idles at around 38 - 42c then I see highs of 75 - 77c under 100% load with furmark.
  • CPU idles at around 36 - 40c then I see temps anywhere from 60 - 70c while gaming, sometimes high 70s. But I have the fan curve set quite low, so I reckon I could reduce the temp further with a more aggressive fan curve.
It's fine, I would leave it be unless it's bugging the heck out of you (OCD) then I would get an aio .
