- 24 Dec 2006
- GB
Looking for a powerful but cheapish battery version for occasional DIY use. Recommendations?
After doing a lot of research I realised there was no point owning a weak impact wrench, so I bought a midrange, recent brushless model from a "proper' brand - DeWalt DCF921.
I then realised for proper torque I needed a 5Ah battery, but that also benefits my other tools like circular saw.
I've since learned about long breaker bars and blow torches so it's full circle.
In theory that's the case, but in practise a bigger capacity battery can deliver more current at full charge without sagging. Useful for those high load situations like big saws, impact wrench, SDS etc.I had no idea the battery size impacted performance!! I just thought it was how long the charge would hold for.
my 899 is a beast. Access can be an issue sometimes though.I plan to get the DeWalt 891 for doing stuff like brakes, it's about the only job on a car I still do myself.
If you buy wired it will do the job just fine. I have a silverline 400w job that I paid around 50 quid. Will do everything from hub nuts to crank pulley bolts without breaking a sweat.
