- 16 Aug 2025
- uk
Had a look at the Phanteks AMP GH 1000W and it looks good but the overclockers website says 3.0 but the phanteks website says 3.1 which do you think is right?
MPN and EAN numbers match with Phanteks site so i would say it will be 3.1.Had a look at the Phanteks AMP GH 1000W and it looks good but the overclockers website says 3.0 but the phanteks website says 3.1 which do you think is right?
ATX 3.x PSUs often have problems with limited PCIE 8-pin connectors/cables I'm afraid, but I think you'd be fine with 2 cables on a 9070 XT with a good PSU.Had a good look at the montech psu's which seemed good and good prices but they have 4 x 8 pin connectors but on 2 cables so share the wattage so not good if i get a 9070 xt with 3 x 8 pin connectors.
Looks like the Phanteks PSU comes with 4 PCI-E cables with 1 connector on each cable.Had a good look at the montech psu's which seemed good and good prices but they have 4 x 8 pin connectors but on 2 cables so share the wattage so not good if i get a 9070 xt with 3 x 8 pin connectors.
You do have to do a bit of work to get them tidy, but i find them easier to work with as single cables lay flatter behind the motherboard tray and i think you get some cable combs to tidy what is on show.Yes the Phantek looks like a good option but there is another thread on this forum in the psu section mentioning the cable management is hard work because of individually textured cables.
It's possible, but I wouldn't recommend it. AMD cards should be fine with almost all old games - I can't think of any that won't run on a 9070 XT that would be fine on an Nvidia card. It's the Intel GPUs that had some problems with older DX9 and earlier games. Perhaps that's what you were thinking of?Another question i have, is it possible to have 2 gpu's in my pc the 9070 xt and an older nvidia one, one to play modern games and one that is more compatible with the older ones, just wondering because i have quite a lot of older ones on steam and i have heard generally that NVIDIA is better than amd to play older games. would the drivers conflict with each other ?.
AMD should be fine for the vast majority of older games, are you thinking of PhysX?i have heard generally that NVIDIA is better than amd to play older games
hwbusters have reviews of all three (well, only the platform for the Phanteks).thanks for the reply, not sure where i read it as i have so many different things on the internet will researching my new pc build. in one of my older questions i mentioned that the overclockers website said the phanteks psu was 3.0 but i checked and they said it is 3.1 and have changed the info on the website so thats good, any thoughts ok my psu choices if the prices where all the same and do you think the phanteks having the 8 year warranty compared to the other having a 10 year warranty matters?.
Well, if you're not confident on the Corsair, in theory you'd need to discount the NZXT too, because the RMx line's OEM has been CWT from the beginning and the NZXT C-Series are almost all CWT too.ok thanks, now i just someone who owns all three or has tested each specific unit to compare them.the phantek is about £20 cheaper, my initial thoughts was get the corsair but as i said in a previous post my last pc came with the RM550x and it stopped working but it did last 5 years so not sure how to decide.
Personally, I don't like that Corsair dropped the -12v line from the RMx, just because of compatibility, so I'd lean toward the Phanteks.
Though, if I had the money, I'd get Antec's HCG Pro instead of all three, which is derived from Seasonic's Vertex. They're not cheap, but a fair number of been purchased on the forums and I haven't seen any complaints yet.
Hard for us to say much on here, but you can get one for less than that.hi thanks for replies, had a look at the hcc pro 1000w but the price is a bit high for me at £190, if i did go for it i would have to downgrade other parts is it worth over the phanteks or corsair or nzxt, i was leaning towards the phanteks because of the price and the corsair and the nzxt didnt seem to have many advantages over it, if i was going to spend the difference between the phanteks at £129 and the hcg pro at £190 i would like to see more reviews as i have not found but a couple.
If you have a look in the PSU forum, there's a thread on the Antec, there's a few owners of the Phanteks too, including a thread on that.has anybody got experience of owning any of my options?
