I have a 4080, it's not fine at all. The developers clearly forgot to keep the PT demands consistent across the levels / maps which means performance is very inconsistent and distracting when moving into new areas which clearly are not as well optimized.Performance is grand from 4080 upwards with path tracing. DLSS (using performance mode) and frame gen gets you a very playable 100+ FPS.
I found myself disabling it completely on some of later levels.
