New home office setup to support 2 laptops?
6 Nov 2002
London UK
Not posted in this section in a VERY long while but need some guidance please. In my home office I currently have a 27” iMac that I use for personal stuff and connecting to work via a remote session. However my work have made to decision to drag us back to the dark ages by migrating everyone from remote VDI sessions to dedicated laptops.
With this decision rendering my iMac useless for work I need to think about alternative options. I have a secondary MacBook for personal use so considering selling the iMac to fund some new kit.
Are there any recommended hubs that would allow me to connect either my personal MacBook or Work laptop via an all in one USB cable that would give the laptops power, connectivity to a wireless keyboard/mouse, a couple of external SSD drives, and ability to display to either 1 or 2 monitors?
Thanks
I'd usually look at Anker for stuff like this, and it looks like their 14-in-1 model meets your requirements. It's kinda pricey though, so I wonder whether you wouldn't be better with living with having a couple of usb cables to swap over each time? Also: I've not used it, or any other of their products, with a Mac so you might want to look into Mac specific reviews.
I've mentioned it in the past but unsure if your situation would work with a Mac as I've never used 1.
I have my laptop and desktop on the same desk and a USB hub.
The USB hub is connected (Via USB) to my laptop and desktop and then my keyboard and mouse connect to this.
The hub detects which 1 is on and allows you to use the same keyboard and mouse without changing any cables, if both are on there is a button I can press to switch it over.
On my laptop I have an HDMI cable connected to my monitor and on my desktop I have an DP cable connected to the same monitor. Again, the monitor detects which 1 is on and displays either of the 2 or I can use the monitor display settings to change to HDMI or DP if both are on.
Link below to the USB hub I use, its currently unavailable as I bought it back in 2021 for when I started working from home but may give you an idea of what I use.
This is only for keyboard and mouse really, the above hub can also supply power for USB sticks etc (but not charging a laptop) but for just a keyboard and mouse its fine without it
The above 1 maybe a good idea but comes at a cost. Mine was the cheapest way possible as I only needed a keyboard and mouse to save me moving cables all the time.
You could also look at higher spec monitors which have a USB-C hub built-in.
For the instance the Dell P2725DE can provide 90w of power to a laptop, you can daisy-chain two monitors together over DP and has multiple USB ports for devices.
  • 1 HDMI port (HDCP 1.4) (Supports up to QHD 2560 x 1440 100Hz TMDS as per specified in HDMI 2.1)
  • 1 Display Port 1.4 (HDCP1.4)(Support up to 2560 x 1440 100Hz)
  • 1 DisplayPort (out) port with MST (HDCP 1.4)
  • 1 USB-C 5Gbps upstream port (DisplayPort 1.4 Alternate mode, Power Delivery up to 90W)
  • 1 USB-C 5Gbps downstream port
  • 3 USB 5Gbps Type-A downstream ports
  • 1 RJ45 ethernet port, 1 GbE
This is exactly what I do with my gaming PC and work laptop.
I used to move cables but that got very annoying very quickly! lol
I feel there's a happy median. I used a USB hub to have mouse/keyboard on a single plug and ran a couple of outputs to both monitors, more cables than the ideal setup, but cheap to set up. I guess it depends how often you are moving the laptops and switching between them.
Thanks for the suggestions, so annoying that whatever I go with will be much more clunky than my current setup. A monitor with a built in hub/power out looks promising but won't be cheap as it will need to be a least the same res as my iMac which was a 5k screen. :(
Why? Work should be supplying you with a laptop.
And you want to keep work & home hardware as separate as possible; you shouldn't be moving external drives between the two. Many monitors have KVM functionality and your workplace should be funding that too.
No work do provide me with a laptop, but previously we had VDI sessions that I could connect to from any computer (via work provided equpiemt to my own machines). Advantage of a VDI setup is that I can be working on my own iMac but then have my work session in a separate window that was totally separated from my personal stuff, it wouldn't be able to access attached drives, but could still using the same mouse/keyboard.
