- 17 May 2025
- United Kingdom
Hi Again.
Since building the PC a few months ago, to my knowledge this problem has only started in the past week.
The issue is that every so often - I get a blank black screen for about 2 seconds - and then everything is normal.
I first noticed it when I lent over the monitor to plug my printer into the USB port, however because I was behind the monitor and not expecting it to go off - I don't know if it went off when I plugged the printer in to the USB port - or because I lent over it - or if it was a coincidence and windows just happened to cause it.
I gave the monitor a little wobble, checked the cables - to rule out a loose connection inside etc - but still I still couldn't replicate the problem.
I then unplugged the printer and plugging it back in a few times - still couldn't replicate it.
I came to the conclusion that perhaps Windows was doing an update in the background or something.
2 days later - I was on eBay and moving photos from my phone to my PC and out of the blue - blank screen for 2 seconds and then back to normal.
This time I was thinking perhaps it is something to do with the USB - but my printer goes in the port at the back of the motherboard and my phone was in the one at the front - so it can't be a specific USB port causing it... tried unplugging the phone and plugging it in several times but still couldn't replicate it.
Everything seemed fine again until late last night, I was watching NCIS on the Channel 5 website with headphones in, when the episode finished I unplugged the headphones from the audio jack - black screen for 2 seconds again... tried plugging them back in again and unplugging them again but still can't replicate it.
What has changed to the PC in the past 2 weeks...
1) I started using a new monitor - my MSI b850 Gaming Plus Wi-Fi motherboard does not have a HDMI port so it was originally connected by a DP to HDMI adaptor and a HDMI cable. (the problem didn't happen with that cable setup - but I only used it a couple of times so that may just be a coincidence)
2) I've updated the bios.
3) I purchased a DP cable with gold connections to eliminate the need for a DP to HDMI adaptor.
4) I've replaced all 6 case fans which were originally on full power all the time as they were powered by the PSU - and replaced them with fans that connect to the motherboard so don't run as fast.
I'm assuming the possible causes are...
1) - Problem with the new DP cable.
2) - Problem with the DP port on the monitor.
3) - Bios problem.
4) - Some sort of driver problem caused by changing the monitor cable - but with my motherboard not having a HDMI port the DP port is used regardless of the cable.
5) - A motherboard or CPU issue that has only started developing recently and may get worse.
I'm still using the stock cooler and my Ryzen 7600 CPU has graphics built in so I don't have a separate GPU.
Not being able to replicate it makes it harder to try and nail down the specific cause.
Could it just be a coincidence that it happened when I unplugged the headphones?
Thought I would ask if anyone else has encountered a similar problem?
3) - Bios problem.
