Cleaning Thermal Paste
You can pop into the chemist and buy a few pre-injection isopropyl wipes. They work like a charm. They might even give them to you for free.
Sorted :)
Temps have dropped LOADS and the thing is silent!
Exactly what I do when I need to clean off any thermal paste
Used some screen clean wipes I had in the end as lint free.
All sorted and really happy with this cooler.
Idle has dropped 20-30 degrees. Not tested any games yet but on boot it was hitting 90 before settling down, hits 50 now.
Hence I needed a new cooler...
What processor is it cooling?
Only a 5600.
I was using the Wraith cooler that was supplied with the CPU.
I did clean it out and re-pasted with Grizzly which helped a tad about 6 months ago. But really, it's never been right for intensive games.
On buying a new GPU I had to get a decent solution.
I have never used alcohol or spirits, it always wipes off fairly easy with plain dry kitchen roll
that's what I started doing after a while and it does the job fine.
I used to use IPA ... I just rub clean with a decent kitchen towel these days... doesn't make any difference IMO and its faster and less messing about.
Another vote for kitchen roll.
I think you used a bit too much paste though, but that's a topic for another discussion lol.
Well you need to use a "pea" shaped size.
And it came out as a stream.
Did what I could do!
When I've used as much as you did, on AM4, it's ended up welding itself to the HS whenever I goto remove it - even if i've ran the PC for awhile to warm up the paste, then it rips it out of it's socket risking damaging the pins on the CPU, all whilst still attached to the HS.
You'll find a load of paste will have gone over the edges to the socket, when you eventually remove it.
Next time you remove it, have a look and see if it has overlapped the edges of the socket, my moneys on that it has. Hopefully it doesn't get stuck to the HS when you do.
FWIW, I'm not trolling you, it just scared me a lot when it happened to me, as the socket was still locked shut, and the CPU would not let go of the HS, and this wasn't a one off occasion.
These days I just use a credit card and smooth over it evenly - I found a significant difference in temps, IIRC around 6-7C when I last did a repaste that way versus a pea or smaller; as I did a back to back test one day, and was glad that I did.
Its a very easy thing to over think.
You need enough paste to cover the surface adequately but not so much it oozes out the sides when you clamp it down.
Thats it. That is really it... everything else is just snake oil.
Yep, less is definitely more.
I've always got better results smoothing it across with a credit card, but I have tried the pea etc, and it's always either missed the corners or been too much and gone over the edges and been a waste, with worse temps.
Years ago on Socket A I used to use a Stanley blade, and spread it very thin, but covering the IHS, again worked perfectly, versus a blob in the centre, which went everywhere over the sides of the IHS.
