Parts from Autodoc arrived faster than I expected. How have I only just found out about them.
I hear bad things about autodoc but I've used them several times now, no issues and about half the price of anywhere else.
What are the alternatives when Eurocarparts don't stock what you want?Personally not a fan of them (they also trade under several different names), they are great when things go well but can be a nightmare when things don't - especially if returning parts to Germany which will often be the case as customs seems to hate car parts, though you can pay the extra for extended return support it doesn't guarantee it is any smoother.
I would never buy expensive car parts from them personally but sometimes they are the only one with stock.
20% off atm if you get the ford ones from ebay.Is there generally any benefit to go with dealer parts for things like a shock absorber mount.
£41 each
Genuine Ford Mondeo Mk5 Rear Shock Absorber Suspension Top Mount 2014- 5278397 | eBay UK
Genuine Ford Mondeo Mk5 Rear Shock Absorber Top Mount Bracket 2014- 5278397. Spark / Glow Ignition. Brake Pad Sets. Drive Belt. Bracket - Shock Absorber. Fuel Mixture. You may have rights in certain circumstances toaccess, rectify, erase, block, restrict, object to or port your information.www.ebay.co.uk
vs ebay generic £28 for two
I normally do euro car parts or Autodoc but they dont have these. Going to do the dampers at the same time using Sachs.
Used them a lot until recently they sent me a wrong part and wouldn't pay for return postage had to get ebay to refund my postage.I get most of my parts from https://www.partsinmotion.co.uk/ through their eBay listings as they often have 20% off discount codes.
I know that. Don't need a copy and paste you find on Google.Car manufacturers do not make parts. Brake discs, brake pads, suspension components etc.. are all sourced from manufacturers who make such parts. These manufacturers make those parts for more than one manufacturer and in most cases, any part that is used by luxry brands like Porsche or BMW - is used by other brands like ford.
In the world of car parts, there are a couple of different levels of what you can do to manage costs. In order
- Branded part from the main dealer of your brand
- The same part, but with a different sticker on it from another cheaper brand
- The same part, from a 3rd party parts supplier, without the manufacturer's logo on it
- A completely different part, produced to the same standard but just from a different manufacturer
- cheap chinese knock off parts, not produced to the same quality, but probably fine. But do you want to take that chance ?
There's a whole community of people on social media whose main reason for their fame on social media is their knowledge of part catalogues and their ability to find the same part but cheaper elsewhere.
Should you only use the manufacturers branded part from your dealer ? Absolutely not - it's proven that they take £5 parts and sell them for £75 just because they have a porsche badge on or whatever. But that's not to say that every part on ebay claiming to be as good as the real thing is indeed as good and not some cheap Chinese knock off.
