S-Trax Super Tweeter
29 Jul 2010
Lincs
Fyne Audio have released a new baby version of their SuperTrax 'super tweeter' the S-Trax and I've borrowed a pair from my audio guy for the week after he demo'd them at the monthly music night on Sunday. Where, I must say, I went in with a lot of scepticism, how is a tweeter that is producing frequencies I can't even hear going to improve the sound! :D
Having done a little reading up on them, it seems they are slightly controversial, with the differing camps for and against, arguing the science of what they do against the 'this is another snake oil' product.
I must say though, it did change the sound of the demo system and everyone in the room seemed to think it was an improvement. In the setup he had it certainly improved the bass response and clarity of the mids.
Having tried them at home for a couple of days now, the most striking difference I have noticed is the extra air/height/scale in the upper frequencies, the choral intro to Lorna Shores Sun//Eater is quite a pronounced difference to me.
Also the widening of the soundstage, and the Fyne F700's I'm running have great dispersion anyway, but with say Tools Chocolate Chip Trip, the width the drums go when moving side to side across the soundstage is just great.
Here they are in situ
Using the conical Trax system Fyne have patented, which they put to good use with the downward firing bass port - the theory being it reflects the bass in a 360* wave rather than directly out of a port, these have the same idea, where the HF are reflected 360* to evenly fill the room.
I'll admit, aesthetically they don't look as good as the full fat SuperTrax version, but with those at £3k you need to have a money no object attitude to life lol. But then even with this baby version at £1k thats not to be sniffed at and we're not talking any night or day changes here, just that last bit of refinement to the sound.
I was worried that adding more HF to the mix could already make the quite forward (not bright! :p) F700's a bit too edgy, but it hasn't and in a way overall I've found the HF just that bit smoother. Though for example with say Nick Caves Red Right Hand, there's a lot of in your face treble at the end and this accentuates that even more, though still doesn't make it too sharp.
All in all I've been fairly impressed with them, especially as I started out thinking they would be a bit pointless anyway, since they start well above my hearing range nowadays which tops out at around 14Khz! Also, afaik, CD quality digital music only goes to ~22khz and these super tweeters can go up to 80khz for the full version, so there's something they are doing in the 16-20Khz range to reduce overall distortion, increasing overall clarity.
Probably want to try moving it around the top (front to back) as that will effect phase response.
Fyne have a list of speakers and the position the tweeter has to be in to align the phase and timing with the speakers tweeter, for the F700's it's 46mm from the front of the cabinet
Welcome to the Fyne Audio club, you've made a good choice :D. I’m running SuperTrax on a pair of piano walnut F502SPs.
I first heard them at the 2024 North West Audio Show and wanted them since then. The sound is absolutely stunning. I’ve grounded them back to the amp, all wiring used is Kimber Kable.
Apparently the S-Trax the first batch is already sold out. My SuperTrax I purchased ex-demo at significant discount from the £3500 retail :eek:, the F502SP's I purchased new.
AP1GczPmd2xXMM5el2eKTbOhvMxzTvOmCO3RshZ8ER-gUGYZjY-falVLVNYig-hu0IMniICIsjM_e_f33ly4RYlPJE_3Mgniw9gio4DCCKu5IC6kfZPMvgiuFu8HOeUMJ1FMVEWfjMb_qVe6lWG8Xy3iP5ajtw=w984-h1200-s-no
That is one gorgeous looking speaker and tweeter. Would certainly pass the wife test aesthetically, not sure about financially though.. lol
Is that an omni-directional super tweeter?
Certainly looks interesting. I head a pair of SWs, probably 20 years. At the time, it would have been such a % of my total system cost, that it didn't make sense. Now, I'm running out of things to do, maybe I should look some more.
Yea, the firing of the HF's onto the cone above is supposed to disperse the waves in a full 360*, it's the same principle they use for their down firing bass port in the speaker, which is one of the main reasons I got the F700s as with my v.small room I've always had trouble taming the bass from rear ported speakers as I just can't get them off the wall enough.
I've been quite impressed with this baby S-Trax version, though as @Admetos shows in his picture, aesthetically the full fat SuperTrax version looks so much better! :D
Yes, it’s omni-directional, so no matter where you are in the room you still experience the effect. It works with any speaker, with a rear dial that adjusts from -3dB to +3dB.
The super-tweeters reinforce the harmonic structure while adding air, scale, and definition, what Freakbro said in this original post is all correct.
At this year’s 2025 North West Audio Show, they were demonstrated on Fyne Audio F1-10s. I asked for them to be disconnected, but they actually unplugged them with music playing, the difference in sound is immediate.
Yes thank you, my GF says she likes them also, that partly makes up for the amount of audio gear I've been buying.
This finish of my SuperTrax is for the vintage series speakers, however as my F502SP's are in piano walnut they match up quite well. Over the cost these SuperTrax are ex-demo from a Fyne Audio dealer, so I've had quite a saving on them.
Is it as simple as just wiring them to the speaker inputs? I assume that they have their own internal crossovers to restrict the frequencies as necessary?
Do they have their own gain controls?
Yes there a speaker in their own right, with their own crossover. I wire to the high frequency terminals of the F502SP's, but you could wire to a speaker that has only 2 terminals also. One limitation is the main speaker should be no more than 98db efficient.
There is a dial on the back that changes the gain from -3db to +3db, the dial control is the flat gold disk you can just make out in my photo.
I guess you could run it off it's only stereo power amplifier. Probably best to isolate from the MF/LF
I've never read anything that's says you need a particular amplifier.
I use a Yamaha A-S1200 these work well with Fyne Audio as their neutral sounding.
Over isolating the bindings posts, since you've mentioned it, I bi-wire the F502SP's with a double run of Kimber 8TC, then my amp is in a+b mode with all 8 amp binding posts in use. Before this I tried a single run of 8TC and used 8TC Kimber jumpers, but the bi-wiring is a little better. Again it's due to separation as you mention.
I didn't say you need, but in principle it's the same as bi amping or triamping, using amplifiers to power each specific driver. Probably wouldn't need much power for ULF anyway, probably 10-20W be plenty.
Best would be active crossovers between pre and power amplifiers, so for yours you'd have LF, HF, and UHF sections, with the speakers and the supertweeters own crossovers bypassed.
I don't have active crossovers in my system.
I kept meaning to ask but how does the music night work, where are you in the country?
It's in Lincolnshire, the music night is at a pub called The Red Lion in Revesby.
He runs them about once a month and either has a rep from one of the manufacturers demoing their latest stuff or he'll choose a theme himself. Recently we had a night listening to 6 versions of rega turntables etc.
I think Chord are coming to the next one, we've had Fyne, JBL, Cyrus and many others over the years. He also did a factory tour of Cyrus over at their manufacturing place in Nottingham, which was cool.
This sounds really good. I would have come but unfortunately your to far away..
Do you get many people at the events, how popular are they. I presume they are organised on meet up.
People don't have access enough to different gear (including myself) but this is helping to solve this.
The Chord demo, I've been in their demos. you should find that interesting if you've never experienced a/b testing of cables and mains products.
I'm lucky in that respect, John lets us borrow anything we want from what he stocks, hence I've had these super tweeters for the week to play with, so I think I've a/b tested just about everything I've bought, inc cables.
When I was upgrading my Kef R3's I had about 20k's worth of speakers in my room at one point haha.
He moved up to Lincs during covid and saw the gap in the market, as our closest high end hifi previously was in Nottingham!, and I was his first ever customer. I always get a good 10-15% discount off rrp too.
He mentioned chord are bringing their new subwoofer cables to the next one.
It's quite a little social club now, with mostly the regulars attending. It can vary from say 6-10 on the low side, with this last one having 20+, probably one of best attended tbh.
He puts the dates on his website, but we've been hassling him to setup a WhatsApp group.
