For a SSF I'm involved in I'm thinking of using smaller diameter soft tubing instead of my norm hard or standard tubing. Traditionally I've used 16/14 hard tubing or 16/10 soft. For this build I'm thinking of trying the 8mm push to fit fittings with 8mm OD and I think 5mm internal.
If I think about house heating loop, there's definitely a school of thought that uses thinner piping rather than the standard 15mm copper, but I wonder whether it makes any difference. I'll be using a DCC pump for the first time over a D5 which won't fit in the case.
Looking at JayzTwoCents he thinks things like clamping force has a greater impact on reliability. Linus found no difference in larger bore tubing, but no one seems to have tested the really small stuff.
thanks
thanks
I should have taken a picture of my build a couple of days ago. None of that clean desk, nicely lit image stuff for me. I had fittings, tubing, coolant, connectors all over the place. Took me an hour to clean up and I'm only half way done
