Just checking in wondering if you are enjoying it yet or have slung it in the bin lol.Thanks for the pointers guys, this is a steep learning curve for me as I have never used any software like this before. I have given up on that idea as I just couldn't get it to do what I wanted, I couldn't even do the "cut" tutorial in Tinkercad despite following the steps exactly. I have found a better poop chute design anyway but I really need to get my head around all this software if I ever want to make the most of my Centauri Carbon.
I have used nylon for some security camera mounts, needed something to survive outside. hopefully it was the best option for the job, time will tell I guess!I'd be curious why you use nylon. "Because I wanted to" is a perfectly fine answer, I'm just curious as to if there are any properties you particularly need for what you're printing. I know when I started, I aspired to be able to print ABS. Now that I can (and have a roll), I struggle to work out why I'd need it. To the point I haven't bothered because of the disadvantages...and ASA that I tried (and used for something because it was the right colour) was a pain.
PET-CF I get. Used that because I really needed the 200°C temperature tolerance for a replacement part.
Nylon I think of for gears but I have heard that the friction coefficient of things like PETG-GF isn't that different enough to make that much difference.
Don't take this as some sort of "You're doing that wrong", I could print nylon, I'm just trying to work out WHY... otherwise I could end up with another roll in storage!![]()
Does the bottom out and pass through depend on the hotend version or brand?I think both flavours are available: those that bottom out and those that pass through.
Also worth noting (in case you're designing something that mates with a PC4-M10) that despite being called M10, they're NOT an M10 thread. They are a BSPP thread (British Standard Pipe Parallel) a 1/8" if I remember correctly.
Yeah, you wouldn't be the first. There are a number of models that have it as an M10 thread but luckily the sizes are close enough that the threads can bite into the soft plastic - not great though if you want to remove them and screw them in again...or just if you like things done properly!I took it as an M10 thread
I love it, I have been printing loads of cat related models and yesterday it spent all day printing upgrades/mods for itself.Just checking in wondering if you are enjoying it yet or have slung it in the bin lol.
I have an M6 (white and a spare with blue) on the metal extruder which does not pass through and the M10 (both have been black) on the hot end which from the videos I have just watched show that is should pass through and the Bowden tube should sit right in up to the nozzle. The one I currently have does not pass through so the filament is getting melted in the chamber (the red block) and clogging which then is causing the extruder to click back.Yeah, you wouldn't be the first. There are a number of models that have it as an M10 thread but luckily the sizes are close enough that the threads can bite into the soft plastic - not great though if you want to remove them and screw them in again...or just if you like things done properly!
Just had a look and it might be that I'm thinking of the PC4-M6 which don't pass through. The PC4-M10's I've got (from the bay) have a black release button and are pass-through if that helps.
That's not a hobby, it's a marriage....or the end of one!I keep telling myself that this is just a hobby![]()
My house has a 2 floor extension (like an annex) connected by a door from the living room. This is in the upstairs part so the noise is very isolated from the rest of the house (especially the rack) as it's double brick wall between the main house so works out perfectly for all the noise everything generates.That's not a hobby, it's a marriage....or the end of one!
Rack (what we can see of it) looks decent but I reckon there's a fair few spindles and 'enterprise' fans in there for a fair amount of noise. Mine's under the stairs so noise is a serious concern - to the point that I went all flash in the end. Once you hear the whine of disk while you're lying in bed, that's it! EK Varder at the bottom of the cupboard for intake and EK Varder for exhaust at the top - down a 100mm duct through 13" of external wall....or at least it WAS external and now it's kitchen![]()
impressive collection.. is it getting much use?My house has a 2 floor extension (like an annex) connected by a door from the living room. This is in the upstairs part so the noise is very isolated from the rest of the house (especially the rack) as it's double brick wall between the main house so works out perfectly for all the noise everything generates.
The rack has 2x Supermicro server chassis which have very loud fans
I must be married to the hobby then as I'm single![]()
Always seem to be doing something on the FDM printers. Resin printers not so much but that's mainly because I have several figurines already printed and want to learn to airbrush/paint those before doing anything else. Thinking about trying out a side business with them which was another reason for getting everything in one space..impressive collection.. is it getting much use?
What about converting one of the filament machines to a laser engraver to mix up your collection?Always seem to be doing something on the FDM printers. Resin printers not so much but that's mainly because I have several figurines already printed and want to learn to airbrush/paint those before doing anything else. Thinking about trying out a side business with them which was another reason for getting everything in one space..
Not really something I'm interested in from a hobby perspective and I think they are still pretty expensive?What about converting one of the filament machines to a laser engraver to mix up your collection?
