That’s an incredible amount of pads you’ve done!!
You would think but I have a massive box full of pads still, over 100 pads easily still in my box.
Fairly sure isopropyl alcohol and lots of elbow grease is the way. You basically need to remove all the sticky residue, and something like isopropyl should dissolve it.Hi Vince I have an old Linux tablet thing that has the kind of textured plastic that gets sticky as it ages and it's now quite old. Is there any way to get rid of the stickiness? Hoping you've come across this in your usual experience! Pink Stuff didn't work lol
Doesn't show all capacitors being replaced, but just the clock capacitor, and there is also a link in the description to confirm the revision.Just bought an original XBox off of eBay and i'm wondering if anyone her could help.
I've been told to change capacitors but when looking online there seem to be different kinds. I've yet to receive this console so i'm not sure what revision this is - could anyone help with where to look?
No idea, never looked for the kit, but probably should do so as I have my OG Xbox from near launch sat in my spare room gathering dust.Many thanks. Could I find these on Ali Express as it's cheaper?
Awesome thank you! Now I need to see if I can find a decently priced solder iron and get practicing!This gets asked fairly regularly in the thread , here's one reply.
I would recommend sitting down and reading the thread, as Vince as pretty new to this stuff at first and it's interesting to see his journey.
This is the one Vince recommends…Awesome thank you! Now I need to see if I can find a decently priced solder iron and get practicing!
