I'll have a try later for you as I use Edge with a 6900xt on latest drivers.Anyone using edge and google street view and performance terrible. Never used to be that bad, is it the drivers mucked up or the edge developers, same with hardware acceleration off and on. On latest drivers. 6700xt.
Just tested on latest drivers and 9070, seems fine here so maybe not a driver thing.Anyone using edge and google street view and performance terrible. Never used to be that bad, is it the drivers mucked up or the edge developers, same with hardware acceleration off and on. On latest drivers. 6700xt.
I'm guessing it's tied to Windows error reports on shutdown and as a fail safe, AMD driver resets to default.The undervolt I've got on my 6700XT is perfectly stable but more often than not, when I restart my PC, it's back at default and I have to reload the profile. Does anyone know why this might be happening?
You got msi afterburner installed? i had the same problem with my memory clocks resetting every reboot but it left my undervolt alone, it wasn't even set to launch on startup but still did it. Uninstalled now and the problem is gone.The undervolt I've got on my 6700XT is perfectly stable but more often than not, when I restart my PC, it's back at default and I have to reload the profile. Does anyone know why this might be happening?
Disable fast boot if not already disabled. That used to reset my wattman profiles occasionally before I disabled it.No, just the standard Adrenaline suite.
Will try the per game profile thing. Thanks very much.
Should be expecting new drivers end of this week / start of next potentially? Given that Borderlands 4 drops in a few days.![]()
- New Game Support
- Borderlands® 4
- Hell Is Us
- New Game Support for AMD FidelityFX™ Super Resolution 4 (FSR 4)
- FSR 4 can be enabled for most games that support FSR 3.1 with DirectX® 12.
- Fixed Issues and Improvements
- Corruption may appear while playing Mafia: The Old Country on Radeon™ RX 6600 series graphics products.
- Intermittent application crash or driver timeout may be observed while playing WUCHANG: Fallen Feathers with FSR 4 enabled on Radeon™ RX 9000 series graphics products.
- Playstation® VR controllers are not detected while playing SteamVR™.
- Intermittent application crash or driver timeout may be observed while playing Monster Hunter Wilds with Ray Tracing enabled and recording with AMD Software on Radeon™ RX 7600, 7700, and 7800 series graphics products.
- Known Issues
- Intermittent application crash may be observed while playing The Last of Us Part II on Radeon™ RX 7900 series graphics products.
- Intermittent application crash may be observed while playing Call of Duty®: Black Ops 6 on Radeon™ RX 9000 series graphics products.
- Intermittent application crash may be observed while playing NBA 2K25 in MyCareer mode on Radeon™ RX 9070 series graphics products. AMD is actively working on a resolution to be released as soon as possible.
- Intermittent application crash may be observed while playing FBC: Firebreak on some AMD Ryzen™ processors such as the Ryzen™ AI 300 series and the Ryzen™ 7000 series.
- Stutter may be observed while playing games with some VR headsets at 80Hz or 90Hz refresh rate on some AMD Radeon™ Graphics Products such as the Radeon™ RX 7000 series. Users experiencing this issue are recommended to change the refresh rate as a temporary workaround.
- Corruption (missing scan travel lines) may be observed while playing GTFO™ on Radeon™ RX 7000 series graphics products.
- Intermittent application crash or driver timeout may be observed while loading a saved game in Cyberpunk 2077 with Path Tracing enabled.
Yeah that is an interesting one!
FSR4 update is interesting
That's amazing news
FSR4 support remains 90 series exclusive.So does that mean my 6700xt can use fsr4 in dune? Or does games need to adjust it or does it still not support 6xxx series. Its a bit vague that line.
