Who said I wasn’t using it? Of course I use it because every single time I get in it I always get more range than the equivalent SoC of a 58kWh version. I also have the option of charging to 100% SoC and getting ~30% more range than I would get in a 58kWh.
As a two EV family we have to share a charger at home and a bigger battery means less charges per week and thus a much reduced chance we have a who needs the charger most conflict.
You keep applying your preferences and needs to other people. That’s not how it works. A bigger battery has objectively a lot more flexibility than a smaller one, this isn’t open to debate really.
A few other subjective points.
1. 130kg is nothing to me for the added benefit of the bigger battery.
2. For me a slight reduction in performance is worth it for the benefits of the bigger battery.
Finally a correction on your power claim. A The 77kWh eBoost does not need 85% to get max power. The power loss is actually linear and quite close to max even at 60% SoC.
eBoost requirements battery Faults and Technical chat for the CUPRA Born - CUPRA Born Forum
www.cuprabornforums.com
