AM4 / AM5 Cooler Compatibility
4 Dec 2015
London
Ok i've tried looking this up and I think its fine but i've got the old version of the EKWB 360mm RGB AIO which currently has my 5950X under it. I've just risen from the dead here (again lol) and ordered some new goodies... I'm pretty sure the bracket is the same but does anyone have hands on experience with the change?
Cheers
I can't speak for your specific bracket, but to my understanding, AM4/5 brackets/HSF's are the same?
AM4 and AM5 mounts are the same. If it works on AM4 then it'll also work on AM5
Thanks folks, that was my assumption also but then I started reading comments from EK about some needing kits etc lol! Much better to get some actual reassurance here, hopefully all good and I can be using it Thursday then.
You're welcome mate!
Yeah, you'll be fine :)
Just got a heatkiller intel to amd conversion kit
From Germany (was a pita as we aren't in Europe anymore)
It's for am4 /am5
There's 1mm difference in the standoffs included
Between am4 and am5
Though can only speak for this specific hardware
