Super budget £600 build?
12 Dec 2005
Hello guys,
My nephew wants to make the move from console gaming to a PC setup, but the budget is limited at £600. He's already got a monitor so it'll literally just be a system only with no OS required as I've got some Windows 11 licences
The games he plays are Fortnite, Rocket League and Apex so nothing super high end but I imagine 120FPS+ is going to be important
Is it doable at all with such a small budget or should be wait and save for a little longer?
Cheers
have a look in the Members Market, some bundles available in there. ;)
Yeah, I think going 2nd hand will definitely give more value for money but ideally I wanted to keep everything new for him but if the budget doesn't allow for that then I'll certainly consider it
realistically for that sort of budget you'd be looking at intel 12400/ryzen 5600
the only caveat is that you HAVE to get the DDR4 ram from the used market as DDR4 is now end-of-life, so new sticks are extremely overpriced
with a few well thought out purchases, £600 will get you a ryzen 5600 build with a 9060xt 16gb
It is doable, you could go with B580 if a 9060 XT 16GB is too pricey, but as tamzzy said, DDR4 is the problem right now.
When you say doable, do you mean brand new or within the used market? The B580 looks like an interesting card, I had no idea Intel made them. I wonder how stable in terms of drivers a card like that is. No gsync/freesync though I'd assume
Brand new, except for the memory.
The drivers are a lot better than they were, but older games can be a problem.
It has their own version of upscaling. Freesync: I think this is supported, but I wouldn't like to just say "yes".
An example spec below. Personally, I'd stick with new parts (except the DDR4) rather than b-grade, but it would put you about ~£30 over budget.
My basket at OcUK:
Total: £602.82 (includes delivery: £11.98)​
For the type of games being played, I think there could be a good argument for a different card too, because Arc doesn't like those kind of games, especially at a low resolution (driver overhead). It is best for gaming at higher res, high details.
absolutely, but OP's budget is a bit low-ish. for £700 5600 + 9060xt 16gb is perfectly doable
for £600, will need a few choice purchases to get the 5600 + 9060xt 16gb...but it's definitely well worth it lol
as a matter of fact, i recently built a 5700x/32gb/9060xt 16gb combo for a friend for a grand total of £510, so it is certainly doable :cry:
I thought I'd give it a go, but:
- I lost 2 cores on the CPU.
- There's no wifi with the motherboard and just 1x M.2 slot.
- VRM might melt with an 8 core (not even a VRM heatsink), so limited upgrade potential.
- Case is small and restricted graphics length (~315mm) which would limit upgrades to 4070 type cards or less.
On the other hand, 16GB GPU, woo!
My basket at OcUK:
Total: £613.87 (includes delivery: £11.98)​
Thanks for the further suggestions, much appreciated
If really needed, the budget can be stretched to £700 if it makes a 5600 + 9060xt achievable. Ideally want to avoid anything b-grade. I can source the DDR4 ram from the MM no problems. The spec above looks good but I'd like a bit more reassurance with the motherboard VRM ideally
easily done, and leaves you with £40 or so to source 32GB ram elsewhere
but as i said, you can trim the budget by looking elsewhere
parts that i would also consider buying b-grade/used: CPU, mobo, RAM, (semi-decent) PSU, air cooler
though definitely get a new case with lots of rgb bling bling for a kid. the case is what makes a used computer look new :cry:
My basket at OcUK:
Total: £662.89 (includes delivery: £0.00)​
The 5600 and 12400F perform pretty much the same, but AM4 has a 5700X3D as an upgrade option, whereas 1700 only has (potentially) dodgy 13th/14th gen CPUs. There's also the 14400F available at a good price some places, which is a better CPU than either of them, more like a slower 12600K (due to the presence of 4 E-Cores), but gaming performance isn't that different.
If you can stick with B550 or B660/B760 that would be preferable, especially if you can get a decent VRM (or at least a heatsink) and 2x M.2 slots. H610 boards are not great and you don't want older AM4 motherboards (like B450) with no PCI-E 4.0 graphics. Not at this point.
My basket at OcUK:
Now this looks brilliant. Thank you. Is that a reasonably sound motherboard in terms of VRM/heat etc? I would have liked a gold rated PSU but I fully understand that at this budget, beggars can't be choosers :D
