new battery. is that 12v or main battery?
Tbh I have no idea they just said it’s a new battery and it’s being ordered from Hyundai.
When I purchased the car the battery health check was ok and the 12v battery was replaced at the last service.
Surely you would ask? Swapping a 12v battery is a 5 minute job, changing the main battery will be hours, if not days worth of work that they'll need the car?![]()
How old is it? New driver seat interesting if new
Ah fair enough. Good to get the warranty jobs in. I booked mine in for the common rear hub click on the 15th but the car goes back Wednesday when the VZ is delivered. Looking forward to it.
From my service this year on the invoice I had a couple of service campaigns they completed, one of which was a 12v battery replacement. As it was serviced last year, (not required but I dont pay so why not) I'm guessing it was relatively recent update.Tbh I have no idea they just said it’s a new battery and it’s being ordered from Hyundai.
Absence of 800V on release of bmw is another negative (merc need to put a 400v adapter in uk stuff though),
bmw had said single speed is a conscious design decision, so if they have the smarts that vw 550 drivetrain has maybe they can compensate in efficiency,
unless you need autobahn max speed
Manufacturers should be upfront on the cd & frontal area.
Even if you get a Leaf and CHAdeMO was no longer relevant you can get CCS adapters these days for them.
Loads of options under £8k, Leaf, Ioniq (28 and 38), MG5, Zoe, Corsa-E, eUp, E-Golf, BMW i3, and a few more. What are you looking for in a car, and what are you coming from?
Stupid me, I don't know how I put £8k, I meant £6k (six). That lower figure is what was edging me towards a Nissan Leaf.
Sorry all who have replied!
That being said, we also have a Karoq as the main family car that does around 12K a year so possibly for shortish trips that doesn't need the space, the EV could take up the slack.
Linked to this, do those of you that have both an EV and ICE car find that you make an effort to do more journeys in the EV due to energy savings?
Currently have a Mk1 Focus and only do 4-5k miles a year, with the longest (very occasional) journey generally being 30-40 miles round trip. So didn't want to spend much north of £5k really as I won't get much savings in the cost per mile.
Anyway, if someone could tell me what the button thing is and how it is secured, I'd appreciate it![]()
It's the charging cable release in case it doesn't unlock.Hi all. We collected the GF's Kona 64kwh on Sunday (22 plate bought from Cinch), and she loves it.
I went over it with a fine tooth comb at the Cinch store before we collected it, and it is tip top apart from one thing..
Under the bonnet in the engine (motor) compartment there is a button on the end of what looks like a cable, or a tube, and it's unsecured and flapping about. It looks a bit like a camera shutter release:
It looks like it should be secured to a bracket bolted to the upper cross member, but there's no obvious way that I can see.
Google lens brings up this picture:
So it looks like the button is secured vertically to the bracket, but I don't think that there is enough slack in the cable to rotate it 90 degrees and position it there.
I think the big orange pipes are coolant pipes.
The car had its 40k mile service at Hyundai in May, and I think this does involve a coolant change. So they might have been in there fiddling about and not secured the button thing properly.
Another thing I noticed was that the little cover on top of the 12v battery terminal was open, exposing the battery terminal.
I reckon the 12v battery was low on juice and Cinch plugged a charger to it and neglected to close the lid afterwards.
Maybe the charger pack was sat on the motor cover and fell off, knocking the button thing off it's mount?
