Caporegime
- 30 Jul 2013
Robert Llewelllyn in the Polestar 5
£140 a month I think!I mean I assume you are so interested in these cars you'll be buying one? Or are you just going to pretend like you are interested, like with the Puma-E when you said that at £350 you'd be interested yet it has been ~£200 per month and you've still not ordered it?
Who am I kidding... pretty sure it is just to add post count at this point in time.
I'm on the OIG and our standing charge is 45.32p a day and 27.77p kWh peak.Maths haven't ever been my strong point (But man-maths certainly are!) so I can't quite work out which plan is better. I'm currently with E-On. I have never switched provider before so I'm not sure how simple and straight forward it is.
E-On 'Next Drive Smart'
Standing Charge: 60p
Unit rate: Peak (0600-11:59) 27.67p/kWh Off-Peak (00:00-06:00) 6.5p/kWh
Octopus 'Intelligent Go'
Standing Charge: 53.7p
Unit Rate: Peak (05:30-23:30) 31.81p/kWh Off-Peak(23:30-05:30) 7p/kWh
On paper it looks like the E-On one is cheaper both peak/off peak but has a higher standing charge.
The bit that confuses me is people say that with Octopus you can end up getting a lot more 7p hours as it can change throughout the day whereas the E-ON one is fixed. But would I be right to assume you would only get the cheaper hours if your car is plugged in? Seeing as I would be at the office 3 or 4 days a week, I wouldn't necessarily be getting those bonus cheap hours during the day?
Yes by a lotI'm on the OIG and our standing charge is 45.32p a day and 27.77p kWh peak.
Does it vary from region to region?
Yeah must vary then, I'm in the East Midlands...Yes by a lot
This is what i'd pay for OIG
Night rate (23:30 - 05:30)
7p
Day rate (05:30 - 23:30)
32.94p
Standing charge
68.34p
North Wales electricity is a lot more expensive than almost anywhere else for some reason, its really annoying!
There's a handy (and incredibly annoying if you live where i do) chart here: https://www.uswitch.com/gas-electricity/guides/regional-energy-prices/
Yes, you only get them if you've plugged it in and Octopus schedules it to charge outside of the normal off peak times and your car accepts the charge.So how do the 7p hours you may get in the day work out? Does it only happen if you car is also charging?
I'm on IOG and honestly I have no clueSo how do the 7p hours you may get in the day work out? Does it only happen if you car is also charging?
You need a compatible car or charger to access that octopus tariffThe bit that confuses me is people say that with Octopus you can end up getting a lot more 7p hours as it can change throughout the day whereas the E-ON one is fixed. But would I be right to assume you would only get the cheaper hours if your car is plugged in? Seeing as I would be at the office 3 or 4 days a week, I wouldn't necessarily be getting those bonus cheap hours during the day?
I don't know about Eon but there's no exit fees on Octopus so why not try one for a month or two and then the other?Both car and the charger I'm looking to have installed should not be an issue
That's the bit I'm stuck on. The car wont be plugged in normally between 0700-1530 Monday-Friday, other than the 1 or 2 days a week I work from home. So I'm not sure if I'd really benefit from the whole house having those bonus hours.
Though things like running the dishwasher/tumble dryer at night may give a little benefit.
You're paying 4p/kWh more with Octopus and barely saving anything else? I'd not switch on those termsBoth car and the charger I'm looking to have installed should not be an issue
That's what my gut is saying to me but I know most people really rave about Octopus so I wasn't sure if I was missing somethingYou're paying 4p/kWh more with Octopus and barely saving anything else? I'd not switch on those terms
