You can see the export limit that is set (and possibly change it) in the v2 version of the Fox Cloud:
https://www.foxesscloud.com/v2/login
Click on "Plant name"
Click "Devices" in the left menu
Click on "Inverter1" then Settings
Click "BatteryCapacityControlAndOff-GridSettings"
Look at the number in "ExportLimit" - That is your number. The default with no limit is 60000.
Can't see that specific setting in the Inverter Settings.
Only the following:
SystemTime
BasicParameters1
WorkModeParameters
ChargingTime
BasicParameters2
SafetyStartParameters
SafetyVoltageParameters
SafetyFrequency
Safety-P(f)
Safety-LVRT
Safety-P(u)
Safety-DCI
Safety-ActiveDispatch
Safety-Reactive
AFCI
PeakShaving
Operation
SegmentedTimeModeEnable
SegmentedTimeMode1
Although under BasicParameters2 I found an ExportLimitedPower which is currently set to "13000 ( 0-30000 )W"
