Pc build for my Mum
16 Jun 2014
I need to build a pc for Mum!
She doesn't need much just something new, good for office workloads only. But she wants to run two monitors. I had though about just using a cpu with integrated graphics but I'm unsure I can run two different displays that way?
Anyone got any suggestions?
Was basing my ideas around this:
My basket at OcUK:
Total: £389.96 (includes delivery: £0.00)​
The integrated graphics in any modern PC should have no trouble with running two monitors, but the outputs on these boards can be very limited.
I'd take a look at Gigabyte's B850M D3HP, it has 2x DP and 1x HDMI.
For CPU, the 7600X is alright, but the 7600 is cheaper and includes a cooler in the box. The 8500G is another option and good on power, though the performance is limited and the connectivity (PCI-E lanes, primarily) is far more restricted than full-fat CPUs like the 7600/7600X (review here).
I'd strongly recommend you get 32GB of memory for the relatively small increase.
Take a look at the NUC boxes by Intel / Asus. My mother loved hers. So small and cute.
Currently the 7600x is just £9 more than the 7600!
They are, I'm not sure she'd like it though...
The gigabyte is on pre-order... :(
and the 7600x is just £9 more right now!
So now I'm wondering about am4 but I really feel that deadlocks the system for later improvements?
My basket at OcUK:
Total: £290.00 (includes delivery: £0.00)​
or £410 for AM5... Not sure if it's worth it?
I'm looking at this, I'd need to buy storage and memory for it and fit it right?
A mini PC is a good shout, GMKTec and others do N100/N105 based machines for well under £200 that would likely be enough for this usage as well as some Ryzen or better Intel chips for about the £200 mark.
£120 gets you
N100
16GB RAM
512GB SSD
Dual HDMI
My basket at OcUK:
No graphics unless you get a G variant CPU.
5600g 5700g
It isn't, OCUK don't sell it. And sure, the 7600X isn't much more, but no cooler means you'll have to buy one.
My basket at OcUK:
You can't fit DDR5 to AM4.
I went the mini PC route for my sister's last build. Plus side, the whole thing hung off a vesa mount. Minus side, it didn't support Windows 11 and obviously can't be upgraded.
I'd go for AM5 to give yourself a bit of future proofing and plan the build around her case preferences
