Forgot to say to check how deep your current back box is, these need 35mm ones.Thanks that looks perfect.
and they're Zigbee.
That spec will be more than enough for HA. I’d add a cheap SSD and enclosure to that shopping list as the SD card WILL fail given time. HA records a lot of data, making constant writes to the SD card.PI5 4gb and POE HAT £72 plus a cheap case. Thats all i would need i think. I want it separate from my server or id install it on my NUC but thats running Plex on Windows.
It’s cheaper than the dedicated Green hardware. I just dont want something thats only just fast enough for it and leaves me no upgrade path.
So would work with the usb ZBT-1 I presume.Forgot to say to check how deep your current back box is, these need 35mm ones.
and they're Zigbee.
So maybe this one would be better, Poe and m.2?That spec will be more than enough for HA. I’d add a cheap SSD and enclosure to that shopping list as the SD card WILL fail given time. HA records a lot of data, making constant writes to the SD card.
How much does it write to wear them out?Yes, definitely IMO. Even if you don’t get an SSD right away, you will eventually because a standard SD card will die.
A high endurance card will last a bit longer but the constant small writes trash them pretty quickly still.
Edit: The SSD doesn’t need to be fast or fancy, I think a PI is only PCIE gen 2 with a single lane so almost any good quality SSD will do.
It will using ZHA, Z2M on that is classed as experimentalSo would work with the usb ZBT-1 I presume.
No idea what the difference is with that I thought ZigBee was ZigBee.It will using ZHA, Z2M on that is classed as experimental
For now I just need ZigBee bulbs and sensors mostly Hue ones, Unifi cameras and lights.Zigbee is the wireless standard, ZHA or Z2M (Zigbee2MQTT) is how Home Assistant comunicates with the devices.
ZHA is built in to HA, so it's easier to get started.
Z2M supports more devices, but you need to setup a MQTT broker (normally Mosquitto).
https://sonoff.tech/en-uk/blogs/new...he-best-zigbee-integration-for-home-assistant
This is a good explanation.
What are the best zigbee bulbs to buy from Aliexpress?
