- 31 Jan 2012
- Droitwich, UK
The newer model was on offer for £650 recently, looks a very good piece of kit for that money.Quite a bit cheaper than the original DWF cost.
I've switched between ultrawides of 34, 39, 49 and 57" in the last two years and I always end up wanting to go back to 16:9 (much prefer ultrawides if the display is used for work, and multi tasking however) but if my main gaming titles are games that will suffer from fish lens effect then a 16:9 is the choice every time.What's the feeling between 32" UHD versus 34" UWQHD?
In some cases you can get otherwise identical monitors with that the only difference (examples of the concept, not in any way recommendations):
MSI 34" MPG 341CQPX QD-OLED 3440x1440 240Hz 0.03ms A-Sync Curved Gaming Monitor
Order MSI 34" MPG 341CQPX QD-OLED 3440x1440 240Hz 0.03ms A-Sync Curved Gaming Monitor now online and benefit from fast delivery.www.overclockers.co.uk
MSI 32" MPG 321URX QD-OLED 3840x2160 240Hz 0.03ms A-Sync Gaming Monitor
Order MSI 32" MPG 321URX QD-OLED 3840x2160 240Hz 0.03ms A-Sync Gaming Monitor now online and benefit from fast delivery.www.overclockers.co.uk
Which would people go for given that type of choice?
I went 34" as it's less demanding on the GPU and to me feels very immersive due to the aspect ratio, but 4K has the benefit of extra pixel density, alongside a newer version of the QD-OLED panel with better text clarity.Which would people go for given that type of choice?
45 is far to big for the very close viewing distance of a monitor right in front of you, be needing to move your head all the time to look around the screen.If you want the ultimate then I’d recommend the LG 45GX950A if you have the desk space, don’t mind the aggressive curve and have a high end GPU to drive it.
Same would go for a 42".42" OLED LG smart TV is the answer, surely?
I'd disagree, down to personal preference of course but I don't find I need to keep moving my head during a game and it lends itself to more immersive gaming experience.45 is far to big for the very close viewing distance of a monitor right in front of you, be needing to move your head all the time to look around the screen.
