- 25 May 2008
- North Wales
For anyone starting to get into EVs is the standard homeplug enough for nightly charging? We currently have two diesel cars and looking into replacing the oldest. Looking around it would cost me around £1k to get a wall charger installed.
Should one get a wall charger first before buying into EVs?
I got an EV a few weeks ago and using the 3 pin plug charger for now until i can get a proper charger installed and... turns out i can manage totally fine using it so i'm really questioning if its worth spending the money on a proper charger.
It depends how many miles you do, i do 60 miles a day and that'll easily charge up on the 3 pin plug in maybe 4-5 hours which fits in nicely with the cheap overnight rates (which i've yet to get the missus to sign up to..)
Yes it is slow to charge up and if you're going from like 20% it will take all day but i don't go very far very often so i wouldn't foresee if ever being an issue for me.
SO yeah depends how many miles you'll be doing, work out how many KWh you'll need to put into the car every night and see if that's going to be comfortable with a 2kw charger.
