Spotify Hi-Fi lossless is (finally) here!
Side by side, current Spotify Vs native 96/192kHz at 24-bit and it is pretty easy to hear the difference, for a lot of what I listen to. Might even resub to Spotify again once it is actually available.
I have noticed this too when comparing side by side with Tidal so im looking forward to when the update arrives
Quite like Spotify, great for convenience, if you like something new on Spotify, go out and buy the album.
HiRes doesn't bother me as the majority is a rip off aimed at mentally ill consumers. But 320kbps or lossless flac is fine for casual listening as it still allows you to hear into the mixing and variations in mastering.
Just a shame I have not worked out how to ensure that the audio output is equal, the variation in loudness between old and new recordings is nippy.
I mean even 192kbps is fine for the casual listener - the majority of people are Bluetooth earbuding or sticking something on whilst they cook dinner. They wouldn't notice
"Spotify hifi" is just cd quality and that's where this is aiming I think. it's a a step up from where they were - which was sometimes upscaling lower quality source to 320 - so I'm happy with the free upgrade. But it's definitely not audiophile lalalala
Re. Normalisation though. I always turn any normalisation off. Do you not?
I believe it's 320Kbps for the premium subscription service, their best MP3 is 320Kbps streaming usually.
Spotify HiFi states 24bit 44.1Flac, CD is 16/44 and as hi res as a human can experience.
Remember all you get with 24 bits is an extra 48db of dynamic range, it's great for recording and mastering as it gives headroom, not so great for home listening. No one records music with that sort of dynamic range. 96db with 16bit is more than enough when you consider the room noise floor to overcome and specifications of domestic audio.
HiRes 24/192 is simply more dynamic range and more frequency beyond 20Khz, it isnt more resolution. No one on the planet can listen to 96Khz and 144db.
Yes I like normalized. Because frankly it sucks to be deafened by the next album due to the huge variation in loudness. Normalization is simply meant to affect volume, so two different mixes have similar output at the speakers, it has no affect on sound quality or actual dynamics according to it's description.
But if the normalization s based on high level at some small section of the album, you then have bits removed for the entire duration of the album.
OK if the HIFI was just upsampled to 24bits, you have some to spare.
spotify equalizer is still useful in the car/carplay versus tidal that doesn't have one, not as good as foobar2k;
where having started ripping stuff with OPUS codec now, like youtube, better quality for your MB
I had spotify for about 6 years, recently broke up with my long term partner who I had a family plan with, so had to restart my plan about 4 months ago.....
I have wanted Hifi for years now, I hope I'm not at the back of the list for the roll out!
this. shouldn't use it if you're listening for pleasure really
Normalisation simply adjusts the volume so badly mastered crap isn't twice as loud as well mastered crap.
It doesn't remove anything as far as I am aware? I could be wrong lol.
Not sure why you mentioned bits, those are not adjusted, and it simply allows dynamic range.
Recording level is a different subject. Hence the loudness wars and why hi res is now a waste of time. Modern music levels are pushed as far as possible, so the recording is louder and sounds punchier, but has no dynamic contrast and on streaming services you end up with different songs with different volumes in some systems.
Quite noticeable if you're driving a pair of large speakers with a large amplifier.
but how does spotify adjust/reduce the volume ? by shifting(adulterating) the bits being sent to the dac/sound-mixer towards the least significant bit.
so if you were listening to bat-out-of-hell say with some very loud sections I wouldn't want the sound on the quiet sections having detail removed because the track had had its volume reduced so the peak level was the same as other music, that might be a lot more monotone - you'd be sacrificing the dynamic range on booh ?
modern music has the reputation of compressing the dynamic range for the typical user listening environment/headphones to boot ? so I guess if you looked at std deviation of level it is reduced.
I've done some rips of vinyl and those sound subjectively better / more involving, than streamed versions.
[if anything, I'd like protection for the loudspeakers on bass notes]
Spotify doesn't remove bits or add bits to adjust volume.
Nor does normalisation remove information or details.
It has the potential to reduce dynamic range, but the target volume is -14db LUFS, which is already the common go to in studio mastering.
I'm reality normalisation is used even when mastering albums, but in the context of Spotify it only slightly helps.
Old 80"s masters are still far quieter than modern recordings so you still have to adjust volume.
But again we are taking about a streaming service where most listening is 320kbps MP3.
If I want quality I will play the CD that has the better mastering which again is more personal taste than actual.
Boo, not active on my account yet :(
I've got it now.
I didn't notice any difference lol, although that was over Bluetooth with a set of Sony wireless headphones although they are not bad headphones.
I need to test it properly on my pc as it has a half decent sound card and AKG wired headphones.
I'm a bit concerned as to how large the music files will be though, as my playlist is large, I'm worried if I set download to lossless it'll fill my hard drive.
Ok tried it very briefly on lossless on the PC, I picked some random Pink Floyd track I haven't downloaded, so it streamed at lossless quality.
Gotta admit, not hearing much difference, sure it sounded good, but I have been using the previous high quality setting, and between the two honestly not sure how much of a difference there is.
Maybe I need to pick a track and listen to it twice in succession, one on high one on lossless.
Maybe I need to pick a more modern track.
I still don't have it as an option, though I'm listening through Creative T20 speakers plugged into a headphone jack in my monitor which comes through HDMI!
I've got a pair of Senheisser momentum 2.0 BT headphones that connect to a HD600 BT dongle which allows aptx and I'm still not sure if I'm going to notice a difference using that.
The amount of people with the equipment/hearing to actually make use of this is about 0.1% of Spotify subscribers.
Ah, if I still had decent enough hearing not riddled with tinnitus then this would be something. Though I'd also need a Spotify sub too...
