Best Cat6 cable
The easier question is what haven't I seen :D
Some horrors include:-
- pairs too far untwisted
- cables kinked or otherwise bent radius exceeded
- different standards used for punching at each end A Vs B
- no basic continuity tests done to check all pins are actually connected.
- individual jackets unnecessarily stripped before punching down
- wires poked into without using punch down tool
- cables cut too short to punch down and then extended using jelly crimps or chocolate block connectors (because it's fine it's not mains voltage!)
- mismatched faceplates e.g. cat6 used on cat5e cable
Ah yeah the good old t568a on one end and t568b on the other. :D we pay "professionals" to do this at work so I wouldn't expect an electrician to know any different! I end up having to go and fix at least 1 socket once the jobs are done. Worst thing is you'd think they'd realise they're doing it wrong when it's different to the other 6 they've completed!
Usually you'll use solid core cable, punch down into the back of the patch panel, and then the front of said panel is now wired-up Ethernet jacks for you to plug in (short) cables to connect to your switch(es).
I am having from wall I'm living.room.uptp loft and was just going to have plenty spare wire and get a male end fitted that can plug into my tplink 8 port switch. So wall socket livimg.room and male end loft.
Basically trying my best to future proof best i Can also have cctv in loft with Internet in there and also possibility of running down to rooms.of needed at some point. Or even do a mesh system with one router in loft connected directly and one I living room.
think I will get someone to come and fit ends to cables if the electrician isn't keen and hopefully cheap. Or ask the cctv installer as think they often do it.
thanks dean
Just curious, what kind of horror stories are there about incorrect network cable termination? Is it stripping too much insulation or what? I'm going to get my house rewired and have started running Cat6 in the ceiling voids, planning to put in ethernet sockets in rooms at the same time but was also considering letting them do the lot (I'd maybe just do the donkey work).
A friend of mine had an electrician do it, and he decided that rather than run two cables to a double socket, he would run a single cable and split it. My mate wasn't best impressed when he found out.
What do you mean by "individual jackets striped before punching"
thanks dean
Mate where abouts do you live? It’s taken me longer to read this thread than it would to have slapped ends on a cable for you.
My best guess is electricians are used to stripping back the jackets when installing cables into plugs or sockets etc but with solid core cables you just punch them straight down into the keystone with the jackets intact, no stripping back needed.
Exactly this - I've seen the coloured individual strands stripped (as time consuming as that must be) on at least one occasion
Bit of a necro post but thought it was better than making a whole new thread.
Looking to run some Cat6 through the home very soon, just wondering what are the best retailers/brands to look out for?
Kenable's own brand , Excel and Connectix tend to be within £10 of each other. Is it worth spending the extra?
Pretty much terrible advice.
There is no need for Cat6A in the home. Cat6 more than supports 2.5Gbps and 5Gbps, and supports 10Gbps at the lengths you will encounter in almost every home.
Cat6A is more difficult to run as it's thicker and doesn't bend as easily, and can a pain to terminate correctly.
Even if you are intending on "future proofing", then Cat6A is a waste as it's not been (and is unlikely to be) ratified for anything past 10Gbps. The next official standard "Cat8" isn't of any use either, as it's only good for 40Gbps at up to 30 metres - so marginal in some home installations.
If you want future proof, then you need fibre optic, but given the OP has mentioned an 8 port TPLink switch, I think we can rule that out of the Ops budget.
Cat6 will be fine now, and still likely be fine for the next 20 years.
This is why I went Cat6 in my new house and not 6a.
Same, was aiming for Cat6a Solid Core originally but couldn't source any at the time, but Cat6 was available (foil shielded solid core) went for it, used it for the hardlines throughout the residence, how have full 10gb network where I'm throwing over 1.05+GB/s from various connected 10gb devices. (Really need to test full throughout, pop open a Ramdisk on the other system and see what I get again, but I believe it was 1.11-1.13GB/s max)
So I agree with the others, if you're only aiming for a 10g (or less) network via copper, then Cat6 will do you plenty in most normal sized residences.
