- 24 Aug 2005
- Uranus
Takes one to know one.Pervert
Guys. I have been playing this. am Level 12 playing as Amon (the big guy) What I dont use is the special powers as dont really understand them and the need for them. He has a firehammer which doesnt do much. Anyone explain this to me am playing on PC and when I press F he does a fire slam but that seens all.
I'm close to giving up on him.I gave up on him just because I didn't like his power, and went for the shoulder gun guy, much better.
Hopefully todays patch helpsNope, I'm going to put it on the backburner until there are some more patches to address the various technical issues. The more I play, the more crashes I'm experiencing and now missions are bugging out.
Stability
- Addressed crashes tied to animation states, audio, and collision checks
- Addressed various 5090 related crashes
Not me. Will try later tonight and see what the score is after the latest patch ( the previous one resulted in more crashes - GPU dumps most of the time ).Not had a single crash since playing on a 5080 OC FE. I wonder how many of the complaints are from people with hardware lacking trying to run badass settings with no upscaling because upscaling "BAD!" lol.....
I'll probably get vilified for this but...
I'm not claiming the performance isn't poor overall, especially on more modest hardware but all this talk of "can't even run it well with a 5090" is frankly ridiculous.
I'm using a 9800X3D & 4090 at 3440x1440 res. Using HUB's 'Quality' setting but with Lighting Quality and Shading Quality on High rather than Medium. With DLSS Quality, which is literally indistinguishable from native res, I'm getting over 100fps which feels totally fine for the hardware used and the visuals obtained.
I'm then choosing to enable framegen to boost the FPS up a bit to the 120Hz limit of my current monitor as it adds a bit more smoothness with no real downsides that I can see but that's a personal choice and by no means necessary.
I appreciate I'm using pretty high-end hardware and I'm not dumping on those with lesser kit but I can sort of see where Pitchford was coming from with some of his comments. Sometimes it does feel that people unfairly criticise a game if it can't run at 100+ fps on a 3060Ti with everything turned on.
Running at 4k, from the launch of the 3090 onwards, I've always found DLSS Quality to be "magic free frames". I can understand frame generation being more controversial and my use of it is situational, but on the high end cards, there's absolutely no reason not to use DLSS Quality.
I even use it on some games where I can hold 4k/120fps without it, to keep heat and power down a bit.
People arent mad because they have to use dlss and frame gen at max settings 4k with a mid tier GPU. People are mad because they have to use dlss and frame gen to get playable fps at 108p or 1440p in a game that looks not much better than borderlands 2 or 3 which would run on a potato. Ive played all the previous entries and would like to enjoy this one aswell but there's no denying that the performance requirement doesnt match the visuals on offer. A good indicator of its poor optimisation is that it runs worse at max settings than Path Traced Cyberpunk and at medium settings on both a 2080ti and 5060ti it has almost half the fps of cyberpunk on medium on the same gpu's.
