Does your PSU only have 1 connector on the cable, or 2 connectors on the cable?any advise on which cable I need or if the PSU is compatible would be great.
C750M CorsairHi and welcome.
What PSU do you have make and model?
And it wouldn’t matter that there’s only a 8 pin in the PSU but 14 in theGPY?Does your PSU only have 1 connector on the cable, or 2 connectors on the cable?
If it has 2 connectors, you can still use it. There is usually a split where you can "snap off" or slide off 2 pins from the 8, to make 6.
Yes, it would matter. I'm not sure you understand my question.And it wouldn’t matter that there’s only a 8 pin in the PSU but 14 in theGPY?
I'm not aware of any Corsair PSU with this model number, do you mean CX750M?C750M Corsair
Sorry yes CX750, so PSU side it has 8 pin GPU side it has 2 4+2 connectorsYes, it would matter. I'm not sure you understand my question.
You have one PCIE cable, right? Does it have 2x 8-pin connectors on the device-end, or just 1x 8-pin connector?
Do you mean cx750m ?C750M Corsair
I don't think there is such thing as a 4+2? But there is a 6+2. If you have 2x 6+2, it should work fine.Sorry yes CX750, so PSU side it has 8 pin GPU side it has 2 4+2 connectors
Sorry yes 8 pin in the PSU and then the other end is 2 x 6+2 connections. Give the GPU is 8 pin and 6 pin will it matter there’s only 8 pin on the PSUI don't think there is such thing as a 4+2? But there is a 6+2. If you have 2x 6+2, it should work fine.
This is all you need just use 8 pin and the 6pin leaving aside the extra 2pins if they don't detach it should still fit leaving 2 pins unconnected..Sorry yes 8 pin in the PSU and then the other end is 2 x 6+2 connections. Give the GPU is 8 pin and 6 pin will it matter there’s only 8 pin on the PSU
So I don’t need more than the 4+4 in the PSU despite there being 4+4 and 3+3 in the GPU?This is all you need just use 8 pin and the 6pin leaving aside the extra 2pins if they don't detach it should still fit leaving 2 pins unconnected..
