Show off your 5090s thread!
Mine
Disappointing. I expected you'd have A RTX 6000 Pro
Seen on a forum people ordering directly from ek are getting them quickly
Just an update on this the 2 guys who ordered directly from EK had their orders shipped this week , apparently 2 days after putting in the order.
I don't suppose any word on the street ref buying from ocuk?
I absolutely hate paying random duty amounts so would prefer a UK shop.
Brexit the gift that keeps on giving :)
Not heard about retailers getting any stock yet ... seems like EK are prioritising their own shop and customers at the minute, probably trying to repair their reputation which has taken a hammering over the past year :o
Im totally with you on the Brexit thing , just had to send a set of ram sticks to Austria to be repaired and needed to do all the invoices etc , absolute load of hassle :rolleyes:
The EK block is a fantastic bit of kit though and really does well at keeping the FE cool, I've just shunt modded mine and during a Steel Nomad run using 850w its sitting at at 19 deg delta :D
Balls of steel to mod it :)
And also balls about EK :(
Been hanging about on Overclock.net, its the normal thing to do on that site ... odd one out if not shunt modded :cry:
But joking aside it can easily be removed if ever needed :)
Hopefully EK start shipped to retailers soon.. they are boasting on FB about how they are knocking out the orders/ deliveries just obviously none to retailers currently :rolleyes:
Finally finished build well almost just awaiting some new memory
I will take some better pictures once the new mem is fitted Nv9 glass is a pita to clean. also still have some rgb to connect once I find the dam spliter.
for those wondering thats a 100mm 420 rad at top a 60 mm 420 at bottom and behind the res/pump a 60mm 360 and stuck to that rad and res is a 12inch x4 monitor I grabbed off amazon.
palit 5090 gamerock with heatkiller block 285k 57p 51E direct die and a jackmo twin fans for memory.
NO coil whine
Case Is now full might just get the lightng kit to finish it off or do u guys think its too much?
What are you guys cards boosting to during cyberpunk? Mine goes to around 2600-2675 whether I increased the power limit or curve or not (uses less power with the curve edited though)
4k every setting was maxed as high as it can get at Cyberpunk 2077. This was tested using even Frame Gen 4 only to see how high fps it will give and listen how much coil whine coming. Test was giving around 385fps which was a bit surprise and boost 2805MHz.
My TUF 5090 boost pretty good all games and zero coil whine. Not asked but like Indiana Jones and the Great Circle 4k all maxed out it will boost 2640MHz+. So boost depending the game what play.
To clarify I don't like to use Frame Gen 4 at all so it is disabled every game I play.
My Gigabyte Gaming OC 5090 is getting +/- 3000MHz in all games with frame generation disabled, that is with an additional +120MHz overclock using Afterburner and +1000MHz memory OC
I've just followed this guide for mine.
Do the more knowledgeable of you think he knows what he's talking about?
Thanks
Scott
I had to buy a cut to size mirrored piece of acrylic for the bottom of my Case Labs case so I can appreciate the lighting on the bottom of the 5090 Gamerock I bought of the MM (and so I can see when the fans are spinning of course)
This is beautiful! I was thinking of trying something like that to enable me to see the lighting on my PSU where I can't see the wattage read out properly, but ended up being a bit impossible to implement.
