- 24 Jul 2009
Thanks, looking to replace hive bulbs I have. They're good but don't offer temperature control or RGB.Sonoff, Aqara, Moes
I can't wait to get away from Hue, added it to Home Assistant and I get so many copies of the same thing two rooms for each room, two lights. So annoying.
About to do the same thing here. My understanding is that it's fairly straight forward, but just a bit of a manual process. The best option is to buy a 2nd Zigbee hub/coordinator that you can assign to Z2MQTT, leaving your original one tied to ZHA. Then all devices remain operational and you can migrate stuff in your leisure. You effectively have to remove a device from ZHA, then put it in pairing mode and re-register it in Z2MQTT. This will obviously have an impact on any automations or dashboards pulling data from these devices and entities but seems the least destructive and takes the pressure off. You can obviously just delete all Zigbee devices and re-pair them all in Z2MQTT in one go but if you've got a lot of Zigbee devices, it could be a bit of a chore!Has anyone got any experience migrating from ZHA to Zigbee2MQTT?
When I set up my HA system a few years ago, I went with ZHA because it was so simple and for the most part it works very well but I'm contemplating changing to Z2MQTT, largely because I'd like to be able to use some Ikea devices (motions sensors, buttons etc and they just don't seem to want to play nicely with ZHA. Some people seem to get them working without any trouble but I've also seen lots of posts of people struggling with devices that HA will recognise but then not display any entities, or they will get stuck during the setup process etc etc. Reading up a good number of people have got them working with Z2MQTT and it has got me thinking about transitioning over to it but it feels like it'll be quite the chore, having to remove all my devices (ok I don't have a huge amount but still...) and then reset them all up and then update any automations etc with the new entities.
Has anyone done this and what were your experiences?
Virtualbox is notorious for exactly that. It’s not a recommended way to run HA. Someone on here has said they’ve been running HA on VMWare without any issues so you could look into that as a solutionDoes anyone use VirtualBox to run HA?
I'm finding Z2M on this increasingly finnicky, whereby it will just lose the adaptor and all the devices will then drop as Z2M stops running.
I have to restart the entire PC to fix it, which might be a problem as I am going travelling for 1-2 months soon, and parents aren't aware on how to restart the PC etc
Thanks
Thanks. I tried vmware a long time ago, but I found it incredibly complicated for a noob like me. Maybe I'll have a go againVirtualbox is notorious for exactly that. It’s not a recommended way to run HA. Someone on here has said they’ve been running HA on VMWare without any issues so you could look into that as a solution
I'm running HA under a VirtualBox VM on Linux headless. I think it's Lubuntu but been ages since I set it up.Does anyone use VirtualBox to run HA?
Thanks
Like you I've come across a few devices that are a bit funky on ZHA. The last one was an Ikea Vindstyrka which doesn't report tvoc with ZHA but does with Z2MQTT. I managed to get that working by using ZHA Toolkit and a zhaquirk based on some info others had developed to make this work but it's messy. If I had Z2MQTT then it just works without any hacky workaround! ZHA is great for general simplicity and for the most part does just work but I'm starting to get into these areas where having a bit more control or better device support would really help. I've been using Zwave2mqtt from day one (Z-Wave JS UI) and it's been utterly flawless so if Z2MQTT is even remotely similar, it should be worth the work! Not sure when I'm gonna try it but hopefully soon.
Does anyone have any speaker they use that is local i.e not google and alexa to get alerts, i would be happy with just noise even but voice would be better.
I want to alert on if certain doors are open at night for example
