Does any info here shine a light on the issue?I just switched to a RX 7800xt from a 1080ti. My monitor has FS2 and worked fine with the 1080 but I get flickering with the 9800 if FS is set to the highest setting in games.. Anyone found a fix? Ta
Perfect.. Thank youDoes any info here shine a light on the issue?
Samsung C49HG90/CHG90 Review 2026: All You Must Know
The Samsung CHG90 is a 49" 3840x1080 144Hz super-ultrawide curved gaming monitor with DisplayHDR 600 and FreeSync Premium Pro. Here's our review.www.displayninja.com
The variable refresh rate (VRR) range amounts to 48-144Hz when the ‘Ultimate’ mode is selected; the ‘Standard’ option is limited to 120-144Hz.
Now, the Samsung C49HG90 has three response time overdrive settings: Standard, Faster, and Fastest. However, the Faster and Fastest modes just enable the 1ms MPRT motion blur reduction (MBR) technology.
MBR eliminates motion blur by backlight strobing, but it sacrifices the maximum brightness in the process and it cannot be active at the same time as FreeSync.
To enable MBR, your refresh rate must be set to at least 100Hz. In order to prevent image duplications, your frame rate should be as close to the maximum refresh rate selected as possible. So, at 100Hz, it’s best to cap your frame rate to 100FPS, and then use either the Faster or Fastest mode according to your preference.
This also means that if you want to use FreeSync, you’re left with the Standard option, which is well-optimized for 144Hz, but at lower frame rates (and therefore lower refresh rate), the overdrive is too aggressive thereby introducing minor inverse ghosting.
So, at lower FPS (Frames Per Second), you might want to disable FreeSync for clearer motion at the cost of allowing screen tearing to occur, but thanks to the monitor’s high 144Hz refresh rate, tearing won’t be that noticeable.
Note that some units of the Samsung CHG90 are also affected by the FreeSync brightness flickering issue.
With the 1025 firmware (or newer), there’s the VRR Control option that fixes the brightness flickering issue with FreeSync/G-SYNC Compatible, but it can introduce some micro-stuttering as a side effect.
I'm guessing it's tied to Windows error reports on shutdown and as a fail safe, AMD driver resets to default.Unfortunately, usually at least once a day, I'm getting the message: default performance tuning settings have been restored due to an unexpected system failure.
No idea why. Using the latest driver.
Beta ran fine on the existing drivers should be fine.Any new driver required for BF6 release friday..i cannot see any mention in the latest driver released. I hope i don't have to clart on installing new drivers on release day.
Do you have any overclock or under volt? I would guess it's unstable I get that with my VRAM on my 7900GRE if I go more than 110mhz over stock VRAM speed even though everything seems to be running fine I will get random driver resets.Unfortunately, usually at least once a day, I'm getting the message: default performance tuning settings have been restored due to an unexpected system failure.
No, no OC or UV currently applied. Seems to be operating as intended over the last few days, though I have no idea why.Do you have any overclock or under volt? I would guess it's unstable I get that with my VRAM on my 7900GRE if I go more than 110mhz over stock VRAM speed even though everything seems to be running fine I will get random driver resets.
Is there any uplift for BF6. For a game without RT, the 9070xt's benchmark results aren't exactly stellar.Adrenalin Edition 25.10.1 Battlefield
Highlights
- New Game Support
- Battlefield™ 6 (DX12)
- AMD Software: Adrenalin Edition 25.10.1 Battlefield™ 6 Preview Driver Version 25.10.25.25 for Windows® 10 and Windows® 11 (Windows Driver Store Version 32.0.21025.25005).
- Ryzen™ AI NPU MCDM Driver version 32.00.0203.297 (Date: 2025-08-25)
will find out later as for performance its sitting above the 4080 super and comparable to the 5070 tiIs there any uplift for BF6. For a game without RT, the 9070xt's benchmark results aren't exactly stellar.
