Gpu support
1 Jun 2012
Hereford
Evening all.
I have a 9070xt nitro + and have just acquired an AP201.
Do any of you lovely lot have the same combo that could possibly measure the distance between bottom of the case and bottom of gpu please as I need to get a gpu support
Going by this video i reckon about 40 or 45mm.
They have fans in the bottom of the case and it looks like you could slide another fan in under the GPU, so that means ~ 50mm,
the GPU used is ~ 4.5mm thinner than your Niro +.
Evening all.
I recently had the Asus AP201 with an RTX 3080 TUF which is nearly a 3 slot card, I bought the Uphere 26-50mm GPU support and it worked perfectly :)
I did have fans on the bottom of the case though, so depends on your setup?
Thank you. Fans be adjusted etc around the support. Haven't built in it yet as waiting to dismantle my nr200p ... the old saying .. can't be 4r5ed is how I'm feeling about doing it !
