Exactly why I'm not hanging around for year 2, if it was slightly more expensive then fine but it's a lot more.
Looking at Zen next I think in November, surely they are better than the likes of Plusnet, Sky and BT.
It's not a little bit extra though it's like 50% more.I'd rather pay a little bit extra for the customer service than the horrendous service i've had with VM - when VM works it's fine for me, but had quite a few issues. Was hoping CF would be enabled in my area but alas.
I'm not sure if I'll keep it once the contract ends. I really like them as an ISP, but it's hard to ignore a massive saving.It's not a little bit extra though it's like 50% more.
It's an individual judgement call with no right or wrong answer. Personally I'd happily pay extra for a great, responsive ISP. I dropped on lucky as heck with YouFibre (2G symmetric, option for 8G plus, with a /29 routed over /31 and a /48 IPv6) and unfortunately Martin just can't match that for me as I'm not a in a CityFibre area. If I was deciding between Aquiss and $random_isp and there was £20/month in it, I'd likely still go to Aquiss unless there were overriding considerations with a rival ISP (local BNG with better connectivity etc). YMMV.
Getting super frequent packet drops on Aquiss at the moment, got a support case in, so a good test of the famed CS at least. Already responded asking MTU, which should be correctly set although took me a minute to find in the Unifi UI, but still dropping. Hoping something easy to fix as it's annoying. Might not be their end, as hadn't noticed in until I had a power cut last night and it caused major issues with my APs so might just need to factory reset my UCG.
