Yeah it was a very wet dough, something like 85% hydration. Some recipes call for 100%+, but probably need longer to proof.
I've never been able to achieve 80% hydration. It's just too wet. Then again, I think a lot depends on the type of flour.
I'm debating trying to start a sourdough starter again. I gave it a go ages ago but gave up as didn't bake enough, however now with a pizza oven we eat pizza quite often and so it'd be good to start again.
Is there any real benefit to buying an old starter batch vs just making your own?
I've got a 12 or so year old Panasonic bread maker that's been squeaking for years, never saw an issue with it.id some analysis on problem with lateral play on the Panasonic pan shaft, maybe 0.2mm, so it is squeeking, haven't dismantled it yet , because it is still usable
usually separates in the fridge with a watery top , and have to stir it before decanting some to make a poulis or re-housing(one a month) and feeding(once a week) the mother,Although seems to be a mix of firmer at the bottom and then runny on top. Has bubbles on the surface though. If i mix it up then it resembles a thin cake batter.
my starters old enough to vote now.
there's a podcast on starters on the bbc from about 2 weeks ago that introduced me to the idea of building a new starter based on apple puree - they suggested it would inherit some flavour characteristics.
(for better or worse)
I used to be able to get good bread flour from local co-operative in France a concept that doesn't exist in the UK - maybe you have some good places in Spain.
I'd try some better flour, definitely something wrong with the rising process.
2nd favourite gadget after coffee machine ... now had to fix the capacitor on the panasonic bread machine ... which was no longer kneeding the bread very powerfully
about £4 on ebay about 15mins, plus 30min dissasembly, belt seems to be fine
Well, 3.5 years later and I've had to press this spare into service. Very weak motor performance,
pan bearing is the next concern - there is a bit of play, so can get some bread residue down edge that needs more thorough cleaning,Well, 3.5 years later and I've had to press this spare into service. Very weak motor performance,
CA05801
CPC
