- 31 Jan 2022
- UK
Unfortunately neither networks are ones that cover my home very well, so if I want mine for tethering....
I can’t really see the point of mmWave for a phone, your hand which holds the phone can literally block the signal.
Likewise, what are you doing on your phone that needs that kind of speed.
mmWave is great for applications where you can put a big antenna on the device so it doesn’t get blocked by the environment it’s in but for almost all of those applications, you are better off just digging a trench, installing conduit and pulling in fibre.
There was talk about it being great for autonomous vehicles etc but it seems things have moved on and it just not being required with all the processing being able to be done locally.
It would be nice when this happens as Three was fast for me around here but Vodafone (Talkmobile) is a solid contender. Be nice to be able to mix it up. I'm sure semi rural and congested zones are being prioritised. I think the sharing has already started!Noticed ads on the London tube network that Vodafone and 3 users can now use each other's network. Has anyone on either network noticed any improvements in terms of coverage? Curious if I should try 3 again, there was too many not-spots around central London and even no 5G coverage around my home area, although Vodafone seems to cover those areas based on their coverage map.
Since this merger my connection seems terrible at home and work Three going downhill
Yes it's unlikely you'll ever see that speed hence me saying a random test.That's extremely rare for Three in London. In the majority of cases they are massively congested and the performance is terrible. So many sites in central London are un-upgraded.
And of course you have the classic EE/Three problem of variable (in my own experience) indoor coverage. They're particularly bad in older buildings but your mileage may vary.
I've seen 300meg at work and 80 where I live. Speeds are generally usable but there times where you hit a black hole. Just like all networks. I find Voda the best for overall reliability.
