New PC for son
6 Mar 2025
Stafford, UK
Hey all. Planning on getting a new PC for my son for xmas, he plays lots of games and current PC is struggling at 1440p.
At the moment he's got some crappy pre built thing from Curry's with a Intel CPU and a 3060TI that sounds like a jet engine, 16gb ram and a terrible case.
Id like to keep the price around 1300quid if we can but dont mind going over if needs be.....
Now i spent 1700quid on my PC built in March and got a 9800X3d and a 9070XT etc etc. I was planning on a 7800x3d and a 9070XT pulse, is it worth stretching to a 5070Ti? Motherboard and PSU options?
I will sell the old PC so that will go towards it.
Thanks.
Thanks.
9070xt to a 5070ti. personally, nope, wouldn't spend extra. the 9070xt is more than capable for 4k, let alone 1440p
I would recommend against the Corsair RMe series, the company changed OEM roughly a year ago and there's been a decline in quality since coupled with numerous reported failures on this forum and others.
Not sure why you included the F12?
Otherwise a pretty solid recommendation for a midi-build vs the earlier M-ATX.
For gaming I'd take the 7600X3D but if saving some cash the 9600X can be a healthy option, it's actually 20-30% quicker than the 7600 in one or two instances such as Asseto Corsa despite being on average around 5-10%.
I have a 9070XT........... was asking if its worth spending extra on a 5070Ti instead of a 9070XT for sons build.......
Thank you for the suggestions. Im thinking the 7600X3D and a 9070XT. Whats the XFX triple fan 9070XT like for noise levels? Im tempted just to get the Pulse like ive got because its pretty good on the noise front.
PSU- 750W is enough?
Performance, no. Unless your son has something he specifically needs from the nvidia software ecosystem, then no.
Pulse is a safe choice. I've got one too
Yes. But if you have the budget or there is a more than reasonable chance of upgrading to a beefier card then get a 850w instead
At one point, the 9070 XT was getting very pricey, like £650+ even for basic models, but now that the Pulse is £570 the 5070 Ti is a much harder sell. There's a value in having something different though, e.g. if you have a game that doesn't like one card for some reason, or a set of dodgy drivers.
