Project: Silent Overkill
Ok, the RTL8127 has arrived as has the PCIE4 X1 cable. ...and that means redesigning everything...again. So a couple of stupid errors later and some PCIE cable tidies too:
In this shot you can see the back of the GPU and also the hex grill that I swapped into the top two PCIE slots:
The part the ribbon mounts to is higher than necessary as I thought it might hold the GPU ribbon clear of the heatsink or even allow the cable tidy to mount to it. I'm not sure I've got there quite yet...but I'm sure there'll be another redesign before it's final! :rolleyes:
The thought also occured - after this print, obviously - that I could, if necessary, tweak the design to put a 40mm Noctua fan in that grill space. It's only a couple of mm off being big enough. In theory this card should run cooler so that may wel not be necessary. Have I not tested it then? Well, no. Obviously I just rushed into redesigning things before I bothered to do that. Really, you're surprised?! :D
I need to nail down where to mount the Aquero and the Farbwerk 360 at some point. I'm not sure where yet. Between the PCIE bay and the PSU is one possibility. It could go in the flat space below (from this picture's perspective) the PCIE bay but the ATX power cable will run through that area and it could get messy....unless I mount it on the ceiling (there's a half door that closes over that area) but then the wiring might be a mess. We'll see I guess.
Alright then. Burdened with the most hideous man-flu I've had in ages, I'm determined to make some sort of progress....anything but daytime TV! :eek:
So I've started mocking up the distro plate and realised I'd got some lovely angles between unbendable things. I really want to use the nice clear, fat glass tubes I used in some of the last build. They only come in straight or a single 90° bend - you can't easily add more bends. So I've added in a couple of Koolance 30° fittings and it causes an offset like this:
Mocked up. Forgive the extension piece, and assume they both get to the same plane - the old bits of glass weren't long enough....but it gives the idea. Not sure if I like the fat 16mm fittings perched on top of the slim 30° fittings.
The other option is to try to keep them straight. Originally there just wasn't enough room for this but there should be just about now that I've redesigned the GPU mount and moved the whole things in slightly. Mocked up with and without the front glass:
I'm after opinions really. Which looks better?
While we're in this sort of area, the plan is to separate the pumps - still in series but not directly from one to the other - I'm thinking one for the link out to the rad and one on the return. I'm also pondering what to do about a res. I rather fancy playing with LeakShield and an Ultitube with that mounted would also sort out a strainer (conveniently built into the base of it and also reasonably accessible to clean if necessary). I could mount one in front of the GPU but it seems a bit heathen to display it and then block half of it. Alternatively I could try to mount it on the external rad. I've got space underneath the distro I could do something as another option but couldn't do a LeakShield that way as it wouldn't have the air gap at the top. Thoughts?
Both look nice but it depends more of the angle you're going to be looking at it, I personally would want to see both tubes more clearly
A very fair point. Both the front and the side will be glass and there will be no corner pillar, so the render is quite acccurate and you should be able to see both tubes from either front or side. I'd sort of got it in my head that the pairs of tubes should run next to each other but the fact that they have to land on the distro staggered doesn't fit with that. If I land them straight on the distro plate, it looks rather like they've been jammed against the front window instead. Not sure yet.
I've modelled up the CPU block and adjusted the position of the ports in the distro - found that they needed to be further away so that the tube was straight into the CPU rather than still being on the curve.
Had a play with modelling up some Barrow 45° fittings that I thought might be chunky enough to match up with the hard tube fittings. They probably still aren't but they are chunky enough to clash in this configuration. This is another option if slimmer 45's were used. The fittings are then in line but down the centreline of the distro plate.
This arrived this morning:
Will need it when I mount the bulkhead QDC's to connect to the external rad*. Of course, the QDC bulkhead hole diameter is entirely and incompatibly different to the hole cutter I purchased previously and naively thought I might be able to re-use! :rolleyes:
The plan currently is to have a 3D printed bracket internally (mounted to the fan plate at the bottom) to back up the sheet metal and have the QDCs bolted through both. I fear the sheet metal alone may be a bit too bendy. Lining it all up should be 'interesting' - especially since the QDCs threaded portion is 15.85mm and the hole cutter is 16mm! Next size up was 17mm and the threaded nut that retains the QDC is only 20mm in diameter...so there's not a lot of tolerance in either direction! Hands up who can foresee me having to make the hole bigger and then custom make a new larger diameter nut! :rolleyes:
*Talking of the external rad, since it's no longer going to be mounted to the side of the case, it could, ideally, be protected on the newly vulnerable side by another grill. It then occurred to me that I had such a grill already as I purchased the deeper one to replace the original to get better fans under it....and it then further occured to me that this had gone to the scrap metal skip at the dump in the major clear-out when the office roof had to be replaced - because, of course, I'm never going to need one of those! *facepalm*
There's a variety of sizes but also grades. There's cheap import (via eBay) that could be perfectly good...or could mangle your important project...which is why I went with one from Stakesys. They have three grades by themselves: DIY (round), trade (Q-Max) and Pro (the ones with the comedy prices :D). I restrained myself to Q-Max! You have to drill a hole large enough to put the bolt through and that then pulls the punch through without making further swarf. They do work for incomplete holes - where you're overlapping the edge of the sheet, but you need more than about 2/3 engagement to get two of the three teeth on.
They also do them for square holes and for massive holes.
I'll shut my trap now :D
I love the concept of clean holes fast when you need to drill then bolt a punch through it instead of just using a hole bit on the drill :cry:
Looks fun though…
You can get much larger sizes and they're probably aimed more at things like electrical cabinets etc. Yeah, it'd be nice to not have to drill the pilot hole so you don't get any swarf at all but it's not easy to do that without dismantling the case into flat panels....at which point the swarf is no longer a problem. You can get a hand punch that will do a hole at least large enough for the pilot, but you'd never get it round the bent edge of the case and it wouldn't have a large enough throat depth to get where you need it. Well, at least for this instance...and I don't think it would be unique.
I'll be honest though, I have got a step drill in my basket that I managed to find (not easy!) that has a 17mm step....in case I need to make the holes just a gnat's bigger. Step drill is the other way of achieving this sort of thing in thin sheet metal....just in case anyone hasn't discovered that a regular drill tends to make a triangular hole.
@DD_Crash Cheers, I'm certainly aiming for tidy. Plenty of wires to sleeve to keep it tidy...once I get that far!
Currently trying to work out if I could (or should!) integrate an Ultitube res into the distro plate. I rather fancy playing with LeakShield and it would be an easy way of integrating that. Not sure if directly mounting it into the plate is asking for either trouble or just causing myself complication....well it's definitely complication, the question is whether it's too over-complicated!
Looking at one of these for the top fans. Basically a 3x140mm fan but as a single unit. Why has nobody thought of this genius before now?! Seems stunningly obvious in hindsight.
It also looks like it can be converted to run standard 4-pin PWM and 3-pin ARGB to connect to my existing controllers. Quite noisy at full pelt...but I don't think I'm going to need the full 2k rpm for 167 m3/h per fan!
With everything else watercooled, I don't think I'm going to need more than just these along the top - there's enough mesh at various places that I could either run them as top exhaust or top intake.
Just sent an email to an adhesive manufacturer asking about the suitability of their product for bonding metal rings to glass tubes. There may be trouble ahead....or they might just shoot it down.
I've got a nice borosilicate tube sitting right here on my desk already so if I can use that and mount a flange to the bottom to screw it down to the distro plate with an o-ring, that'd be a lot easier than trying to cut a threaded boss into the top of the distro plate!
@jonnylaris Cheers.
I've swapped out the 45's so they don't try to occupy the same space, modelled up the NZXT fans - might seem pointless but it can be really useful to make sure things aren't going to interfere with other things - and modelled up what I'm thinking for the res. Totally dependent on if the glue will bond metal to glass well enough. Logically it must be possible or AquaComputer wouldn't be successfully doing it on their res. Why not just buy one of theirs then? I was planning to but if I can put my own flang on the bottom instead of their threaded ring, it'd be so much easier to mount to the distro plate - just screw it down instead of trying to cut threads and then clearance round them etc. This would use their LeakShield module on the top and the filter in the bottom but the glass tube I'm looking at £16 instead of £40 and I don't have to try and remove one of the rings without damaging the glass!
Layout of tubing could still have to change as once I get as far as routing the channels through the block, it might force me to move stuff around...we'll see.
If I do a thin top layer of black acrylic on the distro, I could cut it so the channels sit flush with it like rivers of light....and also not have to sink the flange around the res in quite so far as an added bonus.
Look really good! Out of interest what software do you use to create the diagram/design?
It's all in Fusion 360 which is available free for personal (non-profit) use. The model of the Lian-Li case is helpfully provided by Lian-Li - you can find it on the product page, right at the bottom under Downloads. It's slightly obscurely labelled "O11D EVO RGB STP" but it's a STEP format CAD model which you can import into Fusion 360 (or other packages). A few of the other bits like the model of the EK fitting, bits of motherboard and the AquaComputer flow meter I got from GrabCAD. It gives the framework to then model new items in (GPU block, GPU mount, distro block etc) and also to see if things fit.
Quick update on the res. I heard nothing back from the adhesive manufacturer so I've approached Henkel (the company behind Loctite). I've had a prelimiary reply and provided more detail so hopefully they might be able to suggest a suitable product. One of their questions was how many per day I'd be making...hopefully "one...ever" hasn't put them off too much! :eek:
Alrighty, the fan have arrived! Not a grammatical mistake - a sin, perhaps - but I'm not sure if this should be plural or singular...it's sort of both.
At full 2000rpm they're too loud for a silent build....but you'd expect that. They're not obnoxiously loud but they certainly aren't silent. Had a quick play and at 800rpm they're silent and create a gentle breeze. Currently set them to 1000rpm and they seem silent when not mounted...we'll see once they're screwed in. Plenty of headroom to balance noise and flow though.
The RGBs are 8 per fan and they're sequential. What's that mean? Well, over one single ARGB connection, you can independantly control each LED individually. Want one red, one green and one blue? Not a problem. A pattern scrolling over all three? Fine.
Proprietary connection I hear you ask? Well, yes. It's an 8-pin ribbon lead with a latched 8-pin DuPont connection but they provide a convertor that splits that off into a standard 4-pin fan connection and a choice of 3-pin ARGB or 4-pin NZXT RGB only. I wonder if the extra pin might be a passthrough or daisy-chain connection so you can chain additional ARGB LEDs onto the end.
Talking of RGB, the light shines through "semi-translucent blades and frame side windows". The sides are nowhere near as bright as in the marketing pics as there are only LEDs in the fan hubs and not round the sides as you might have expected. That might be a Gen2 feature :rolleyes:
Overall, I think I'm happy with them. They're not cheap...but show me a quality fan that is...or anything these days! They work out at just over £20 a fan so it's at least comparable to decent fans...and I think the single frame idea is great; should be so much cleaner as a finished look.
That's a tidy block of fans I must say. Now get a multimeter, map out all the pins and cables and rewire the entire thing to do it justice :P
Good to see you back LP. Cheers. Well, I did literally ask you to make my life more difficult in this!
I was thinking it ought to be possible to make the wiring tidier just by putting direct plugs on the wires - rather than a proprietary plug with a converter loom. If I split it and paracord it, it's going to make it into 3 separate runs as it takes some really thin insulated wire to get four down a single 550. I have some but then it would have to be spliced somewhere...and I'd still end up with two. I'm not sure yet but I think the ribbon might actually be fairly invisible in the top and I'd only have to worry about the 'last mile' getting it to the Aquaero and Farbwerk 360.
That said, it would be rude not to map the pinout if someone hasn't already done it... which they probably have. My money is on the extra wire being a return from the end of the ARGB pixel chain so you can have the next set of fans chain off it. That fits with what you get in AquaComputer's strips with their 4-pin connector and with individual ARGB LEDs too...but I'm not sure it fits with the NZXT CAM setup as I think each item connects back to the hub. Might be a job for my cheap and nasty USB oscilloscope with it's wibbly wobbly trace!
