Upgrade Sanity Check
22 Mar 2004
Upgrading from a 2019 3900x build utilising x2 m2 SSD, a MSI 4070ti, a EVGA 850G2 supernova PSU & Phantek Case
Upgrading to
Your Order​
1 X AMD Ryzen 7 9800X3D Eight Core 5.20GHz (Socket AM5) Processor - Retail - £399.95
SKU
: PRO-AMD-03517
1 X be quiet Pure Loop 3 240 High Performance All In One CPU Cooler - 240mm - £64.99
SKU
: COO-BEQ-06197
1 X Corsair Vengeance EXPO/XMP 32GB (2X16GB) DDR5 PC5-48000C32 6400MHz Dual Channel Kit - £119.99
SKU
: MEM-CRS-03744
1 X Gigabyte B850 GAMING X WIFI6E (Socket AM5) DDR5 ATX Motherboard - £194.99
SKU
: MOT-GIG-03858
Grand Total: £779.92
Mainly used for gaming @ 1440 and trying to keep price as best current bang for buck but around 800ish, any advice of the components i have in the basket?
Thanks,
I haven't looked in much detail, but the Gaming X is one of Gigabyte's lower models and you can buy an Aorus at OCUK for similar money (admittedly, white), which I would expect to have superior specs.
Not all CPUs are able to run 6400 optimally, so it is safer to go with 6000, though you could just manually lower the frequency if necessary.
These CPUs can be cooled with a peerless assassin/phantom spirit if you'd prefer not to spend that much.
My basket at OcUK:
Total: £709.87 (includes delivery: £7.99)​
Thanks for the input. I've added that RAM, probably still keeping the AIO cooler and the sapphire mobo is preorder, so looking for something similar in stock. I don't need WiFi, a mad overclock or a silly amount of usb's or SSD, just something that works well.
