FTTP install question regarding power points
14 Dec 2005
full fibre cable has already been run to outside my flat (every flat in the bloack had this done last year), same route as all the electric/copper phone cables that go in to a cupboard with the fusebox/meter
if I just have a loose double extension lead in to the cupboard from a socket in another room will they install?
The 'engineers' want to do a job and get paid, they won't argue with you if the ONT can get to a state where they can complete the job. The only reason all the guides say you need a double socket is so that people are aware it needs power.
I was just thinking when Sky boxes had to be connected to a phone socket they wouldn't (shouldn't!) leave the phone cable loose, always tacked to skirting boards etc.
I suppose the difference here is they haven't 'installed' the extension lead so not their problem
Hmm...so could have the router wherever (next to a socket) run ethernet cable between ONT and router and power ONT using that cable?
More usually a PoE switch, but yeah. You just need a PoE to 12v splitter (2.5G if you have a >1G package). Not an officially endorsed method(!), but it works.
