Stripped things out, verified no blockages (or so I thought).
Presumed motor was on the way out or the pumping action was worn.
Bought a cheap motor from the rain forest. Despite being supposedly compatible I had to switch the input polarity to make it operate front Vs back correctly.
Anyway, it was much weaker than the original motor so I switched them back and now think there's something else going on.
Am I dismissing the pump as the culprit too soon given that it was a cheap Chinese knock off? My reasoning in buying was that I would expect it to work but maybe not last as long, at which point or sooner I could buy a decent unit. Basically bought it for diagnosis purposes/ temporary fix.
Other than tubes being pinched or blocked, any other ideas?
