ChatGPT Sorted my Car
18 Oct 2002
Aberdeen
I don’t know if anyone remembers, but a while ago I was having issues with a loud squealing noise coming from my engine. I took the car into the garage, and after hooking it up to the laptop they said they couldn’t see what was wrong with it. The only clue was that the noise stopped when the oil filler cap was removed.
I put this into ChatGPT, and it came back saying it was 99% sure the issue was a faulty PCV (Positive Crankcase Ventilation) valve. Turns out it was right. I asked the garage to replace it, and since then there’s been no noise at all.
Just goes to show—unless it’s a dash light or a computer error code, the art of modern mechanics diagnosing issues themselves seems to have disappeared.
It's a trade off - mechanics have their hands tied these days, if they suggest replacing something that might cure a fault and it doesn't, then the customer will complain that they've wasted money
The amount of times I've used ChatGPT for my bike project is nothing short of alarming. And of the dozens of times I've used it, it's been wrong once. Even then I told it that it was wrong and it had a rethink and spat out the correct answer.
Something else I also clicked, is that you can use it to find answers in foreign languages which is very helpful. I was after a proper Turkish chicken shish recipe, so I asked it to find me one on a proper Turkish website and ten seconds later I had one.
I absolutely love ChatGPT.
yep trying to save daughter some money..... expansion bottle gets low on water every couple of months literally 10 to 20 mm.
daughter worried so put the pressure tester on it and no drop over a couple of hours.
local garage she has her tyres at reckon its a tiny leak in the radiator?? quoted 200 notes to change. shes adament it must be right cause they have told her. so guess who is changing the rad....(100 quid probably for nothing grrr)
Probably a tiny split in a pipe, perhaps even an ever so slightly loose hose clip that only allows a small amount out when the engine is warm and the coolant is hot and the pressure is higher.
what's the latest on the recent heater problem/thread though ? with blower/hedghog/fuses changed
Electronics… I’ve already spent nearly £800 on brakes, a suspension arm, pads, and now this valve. The heater will just have to wait a month or two. Got myself a thermal blanket for the window and I’ll be sticking with the old 2-litre warm water trick on the dash — it works.
Car’s turning into a money pit, but I can’t afford a new one. Only 37k on the clock, had it since new (62 plate). Mechanically it’s sound and the body’s in good nick — just these annoying bits draining the wallet.
Having bought many a cheap car I've always found bits start failing due to age after about 10-12 years regardless of mileage and there's not a lot you can do about it. Which worries me as my BMW is now over ten years old.
As long as you check the sources to ensure there's no weird stuff popping up with anything particularly important, ChatGPT is probably the best "search engine" on the internet right now tbh.
It's barely worth using Google or the others, they just use crappier versions of AI + insane filters and advertising to the point it's a waste of time.
