- 23 Mar 2011
I keep thinking about picking up a Cooper S R53. Budget approx £3-4k as a fun/run about car.
Would this be ill-advised?
Thanks for the info! Definitely want to find one that's been looked after etc.It isn't ill advised. If you manage to buy well, parts are common, you can mod to your hearts content if you fancy.
But they are starting to cost more and more the older they get mind, they are now 20 year old cars. If you look at facelifts which is basically 2004 - 2006, BMW seem to have changed something in the build, but they are starting to rust not just around the rear lights/tailgate, but on the rear bulkhead under the rear seats. My battery box has also started to rot out. If you use PH a few readers cars have popped up with rust in the same areas recently.
Prefacelift cars seem a lot more resilient. My Mini chap has a similar mileage car to mine but PFL (Circa 150k miles) and his rear bulkhead is pristine.
This one's popped up locally but not sure on the colour or the 53 decals :| otherwise seems a good example
http://www.autotrader.co.uk/car-details/202509296710142?utm_source=share&utm_medium=android-app
This is great, thanks! I'll take a look for the 1.5 petrol, although tbh I'm almost tempted to try to find an R53 for £3k or so, similar to @kinger8938 .2014 is the F56 Model, and generally yes they are more reliable, however they are also more complicated (as generally have a bit more tech etc)
I drive the older R56 Cooper, but also own a F60 Countryman Cooper S. Honestly I find the Cooper more fun overall as it's got enough power to be fun, but not so much that you're constantly thinking about losing your license.
The Cooper S (both my Countryman, an F56 courtesy car, and my previous R56 Cooper S) constantly urge you to drive faster, and it's too tempting - especially the F56 they are a lot more refined, so easy to hit license losing speeds without realising. The majority of fun in a Mini comes in the twisty bits (and roundabouts) anyway - anyone can drive fast in a straight line!
The Cooper should be no different on a Motorway (in fact might actually be a bit more comfortable if it has smaller wheels) etc, but I will say the F56 is a lot smoother and more relaxing on long drives than the earlier R56.
Shouldn't be much difference. The 1.5 Petrol is essentially very similar engine to the 2.0 just with a cylinder less (as it was designed as a modular engine - which also includes the 6 cylinder in BMWs)
Aside from the black wheels, same colour scheme as my R56 Cooper - I wasn't sure on the colour when I got mine, but it's absolutely grown on me - looks much better in person than photos.
Surely of all people on this forum you're capable of changing that, VinceRandom
Is there some magical way of changing the ambient lighting colour I dont know about?Just picked up a 2017 cooper yesterday and all the lighting is a pink/purple and honestly looked in the menu for 5 mins but couldnt find anything obvious.
Surely of all people on this forum you're capable of changing that, Vince![]()
Yea I havent RTFM, only picked up the car yesterday morning and had a quick look through the computer thingguess I will have to read the manual.
One of the switches near the rearview mirror will change the colour.
Press the toggle on roof console to cycle through colours. Hold it until it flashes if you want disco mode where it cycles and the toggle the other way is for brightness.Random
Maybe there’s a toggle to turn up your brightness?![]()
Do you mind me asking what it set you back, and its mileage? Very tempted by something similar!Here is the car. Has chili pack, rear sensor all the keyless stuff, auto lights, Bluetooth stuff etc. pretty well optioned car... Decent little upgrade to our run around. Drives really quite nice as well.
Just got the plate on the Clio back onto retention so once the logbook is here should just be able to throw that on the mini.
