Why you SHOULD be using Firefox
Anyone having issues browsing the forum using the latest android version?
For note - this seems to be happening to me. https://support.mozilla.org/en-US/questions/1530869
For note - this has now been fixed from what I can tell. Also updated Fennic which I had to use as a stop gap and that seems ok too on the latest FF version. Think I might stick to Fennic purely so I don't have to deal with swapping back
I have not experienced what you have noted, with those screenshots. But I have experienced some irregularities when using FF on Android.
When posting within Facebook groups sometimes the keyboard, SwiftKey, covers the space allocated to type. So you can type but not see what is written.
Lowering the keyboard at that point can back out of placing the intended post and might return to the main page of the group. All a little vague as it isn't consistent.
There are some other minor irregularities related to forum use that just makes it a little frustrating at times.
I'm not sure if SwiftKey could be involded, or if I change it to using a desktop site, rather than mobile, that could help...... for testing.
I've encountered this before too, however I can't remember if it was when I was trying out Swiftkey or not, might have been gboard. IIRC I normally dismiss the keyboard and then call it again and it works. Thankfully it's a very rare issue for me. My phone is still on A10, so pretty old.
I've not noticed any other issues thankfully.
FWIW it is even worse when using Edge, especially if you need to edit your posts.
I have found with FF if the keyboard covers the space where you without type then just pressing a letter on the keyboard will reveal it. The keyboard remains also.
