Network Overhaul
29 May 2012
Dorset
Morning all
Im very overdue a local network rebuild at home so as its been a while im after advice
Current setup
VM 1gb/s router, wifi switched off ( its bugged firmware needs a factory reset to get it back on) This is at one end of the house in my box room / study
Old TPlink router only runs 5ghz no 6/6e support. This is in the middle of the house with a cat6e link, I get approx 100mb/s in most areas of the building
Usage
Couple of laptops, max of 3 tvs. PS5 2 pixel 8a's and my daughters fire kids tablet. Main PC and Linux NAS server are hardwired back to the Superhub
Long term goals
Move to at least 2.5gb/s for hardwired links
WiFi 7 with 6ghz support, may as well if Im doing it, possibly 2 APs rather than one to spread out over the area a bit better
Implement sufficiant parental controls, daughter is currently only 5 but if Im rebuilding I may as well plan hard for the future, I already have her tablet locked down but id like something centralised so I can control multiple devices, a plus would be with some level of VPN support baked in
Pricing
Lets be honest as little as possible to cover the bases. I dont need Enterprise grade firewalling and management with 99.999% uptime and failover, I dont have or need 10gb fibre links this is for 2 adult and 1 child in an average sized 3 bed semi, I dont have Cameras, doorbells and Voip phone systems to worry about.
Ive been looking at ubiquity and thinking maybe a Dream router 7 and a u7 pro? Or am I better off spending the extra and going for a cloud gateway max, a couple of u7's and a POE switch / injectors? Although price really starts to ramp up doing that but I do understand the benifits of versatility having seperate boxes to do dedicated jobs allowing easierr expansion later on, I hear this can become a bit of a gatweay drug for the unifi product stack :D
Whats the unifi parental controls / content filtering like?
The content filtering is pretty good, it enforces safe search on; YouTube, Bing, Google. And blocks adult sites. If you want more fine grain control of what is blocked, where the block lists get added to daily, some of which is not necessarily adult, but you may not want your kid to look at when they get older, there is a premium subscription service. But for porn and violence, the basic filter is most probably good enough.
I've had a Firewalla Gold SE for a few months now and it works really well and has lots of cool features. Might that be of any use in your plans?
Firewalla Gold SE
Do you even need 2.5G? It sounds like you'd be better served asking VM for a working Hub and then just setting up something like ControlD DNS - one profile for you and your wife (basic ad and tracker blocking), and one for your daughter (ads, trackers, adult, gambling, drugs etc). Sorted.
Stop and think about this for a moment, you can spend £40 on a switch and £15-25 on adapters for your NAS and PC to communicate at 2.5Gb, or the same and they can connect at 10Gb via SFP+, but if you are only streaming media from your NAS at 20Mb/s, then it’ll still only be streaming at 20Mb/s. You’ll still be limited to gigabit WAN, so it’s only devices on the switch that will benefit at this point.
