So you decided not to use the WD Black SN850X 2TB. Did you buy the 512GB Intel NVMe new?Got my UGREEN enclosure on Tuesday, dropped a cheap Intel 512 nvme in there.
@malachi Out of interest with the UGREEN enclosure; did you use that odd squishy cream gel strip, which I guess acts as a bridge between the ssd and enclosure lid, or something else?
I used the one that came with mine, its like a themal pad to help to dissipate heat. Sits on top of the drive. You can buy them new on eBay and Amazon if you need replacements.@malachi Out of interest with the UGREEN enclosure; did you use that odd squishy cream gel strip, which I guess acts as a bridge between the ssd and enclosure lid, or something else?
Appreciate the reply. Enclosure is 8 stops away so I guess I'll be for round 2 momentarily ...I used the one that came with mine, its like a themal pad to help to dissipate heat. Sits on top of the drive. You can buy them new on eBay and Amazon if you need replacements.
Sure you bought an enclosure capable of 40Gbps, sounds like you've got one only capable of 10Gbps.e2: Pffft, started a speed test and I'm averaging ~800mb/s read and write. Gah.
I think I just have wonky luck. Started another stress test and the drive disconnected. Unplugged and plugged back in. Retested and now getting around ~3000m/s Read/Write.Sure you bought an enclosure capable of 40Gbps, sounds like you've got one only capable of 10Gbps.
