4K UHD Movie streaming rig
I use Photoshop, I rip 4K UHD Video, what kit do you reckon is the best option for me?
Many Thanks.
I'd normally only want to make the recommendation after you've done some kind of usage monitoring with e.g. task manager, because otherwise you might be buying way more than you'll need.
The Corsair 64GB kit for £140 is better value though, per GB, so in the absence of any other info that's what I'd buy.
Many thanks, Tetras. Would the 64 GB kit need XMP/EXPO? I'm not sure what that means. I've not built a PC in a very long time!
I'd need the exact model number to say, but probably to work at the rated speed: yes. You have to go into the BIOS and turn XMP/EXPO on, which increases the memory speed and memory voltage, among other things.
JEDEC kits are usually 5200 CL42, 5600 C46, 6000 C48 and 6400 CL52, though depending on the motherboard BIOS they may only boot up at 5600 since that was the max speed when DDR5 launched.
Here's what MSI say on one of their boards (Z890 Tomahawk), which suggests it is ready for 6000 and 6400 and won't boot at 5600:
4x DDR5 UDIMM, Maximum Memory Capacity 256GB
Memory Support 9200 - 6400 (OC) MT/s / 6400 - 4800 (JEDEC) MT/s
Corsair Vengeance: 64GB (2x32GB) 5600MT/s DDR5 Memory Kit CMK64GX5M2B5600Z40
Motherboard: Asus Prime Z890M-Plus WIFI (LGA 1851) DDR5 mATX Motherboard​
Update on build, this is what I have so far:
Case: Fractal Design Node 804
Motherboard: ASUS PRIME Z890M-PLUS WIFI Intel Z890 LGA 1851 (Socket V1) micro ATX 6 sata ports
CPU: Intel Core Ultra 7 265k
CPU Cooler: Cooler Corsair Hydro Series H100i v2
CPU Bracket: Asetek Premium Retention Kit Intel LGA 1700 (35-150-0000021)
RAM: Crucial Pro DDR5-6000 RAM 48GB (2×24GB)
Hard Drives:
223GB Crucial_CT240M500SSD1 (SATA (SSD)
1863GB Western Digital WDC WD20EARX-00PASB0 (SATA )
18627GB Western Digital WDC WD201KRYZ-01BBDB0 (SATA )
9314GB Western Digital WDC WD100EFAX-68LHPN0 (SATA )
1862GB Western Digital WD My Book Duo 25F6 USB Device (USB (SATA) )
SATA Expansion Card:
No w looking to source a Sata Expansion card, that wil support me adding a few more 20tb drives in the near future, I'm currently looking at the LSI SAS 9300 16I HBA Expansion Card 16 Ports 12Gb/s SATA SAS PCIe 8X for Linux VMware FreeBSD, just wondering if that is a good choice, or is there anything better that you guys can recommend?
