Best Retro Handheld
I've ordered the Xbox Ally X this morning and will be loading it up with a full compliment of retro catalogues.
Absolute overkill and won't do much different from my steam deck in terms of retro but will share detail in here if people are interested.
I've never even heard of an Xbox Ally. Is this the same / similar to ROG Ally X - https://rog.asus.com/gaming-handhelds/rog-ally/rog-ally-x-2024/
Is this the only difference 'Complete with impulse triggers for enhanced control.' - https://www.xbox.com/en-GB/handhelds/rog-xbox-ally
Are no it seems to be AMD Zen 5 and slightly different GPU and CPU clocks - https://retrocatalog.com/compare/rog-xbox-ally-x/rog-ally-x
Yeah it's a new XBox branded ROG basically. With a Zen 2 Extreme and some rumbly triggers.
Should be a decent upgrade over the Steam Deck.
Is this the right URL? I'm not seeing anything apart from viral Imgur pics.
Imgur always changing the mobile app how links work
desktop generated link
1240 x 1080 Winlator Max Payne.
I'm guessing the blue and white lines aren't normal? Any idea how to resolve these? Also noticed some other artefacts . Emulator is M64plus fz
Update: Resolved this by choosing another emulation profile for the game, although the clarity/detail of textures are not as good in this profile.
GarlicOS was/is fantastic but doesnt offer support (or didnt in the past) for N64, Dreamcast and some other systems. That being said, I have the following on mine-
Amiga
Amiga CD32 - doesnt play well / testing
Apps
Arcade
Capcop CPS1, 2, 3
Doom ports
MS Dos
FB Neo (arcade)
NES
Gameboy
GBA
GB Colour
Gamegear
Jaguar - doesnt play well / testing
Lynx
MAME
Genesys (Megadrive)
Master system
MSX
Neogeo
Neogeo cd
Panasonic 3DO - doesnt play well / testing
TurboGrafx16
Pico-8
Ports
Playstation
ScummVM
Sega CD
SNES
Sega CD 32X
Virtual Boy
Videos
Sharp X68000
It boots up in less than 10 seconds from pressing the power button and powers off in less than a second.
Having a bit of trouble booting into sega cd games from the consoles section. I can get it to work from retroarch and selecting a different core. Is there anyway to change that to the default sega cd core? Also getting a "bios not found" on PSX games, though they are playing okay. Pretty sure I have all the bios that came with tiny best set in my bios folder!
90% chance it’ll be poor bios/roms. Best tiny set should be rebranded ‘terrible set’
Have a read of this and get the correct files :)
Nice one. Will investigate.
Damn this hobby, I've just purchased an RG40XXH as I was finding platform games a bit uncomfortable on my vertical 35. Totally didn't need another console though..
Dont worry, before long you’ll be on your 10th handheld :D
I started out with a psp go which I found out could do psx properly and also basic emulation, then got an RG35XX, then went all out with a Steam deck. Then back to smaller handhelds.
RG35XXH was quite nice but always found the H700 chip & Mali gpu lacking for systems more demanding than psx (and if you want to upscale)
Snapdragon all the way for psx and above.
I would highly recommend the Retroid pocket classic 6gb / 128gb version (£106 delivered), though the buttons are quite loud which is a bit annoying and no analog sticks. 6 button means you can map 4 as a stick or use the touchsceen to play games.
Winlator it’ll run Max payne at 1240 x 1080 (native res) which is surprisingly playable with settings maxed out.
Virtua tennis 2 will upscale 2x (1280 x 960) and runs 60fps.
Snapdragon G1 gen 2 isnt great on the gpu front but is highly efficient and the cpu is really strong for the cost - PS2 runs native or 2x on some games which destroys more expensive devices like the RG Cube and 406H which I sold on.
Anyone used muOS on an anbernic device? Just installed on my 40XXH. Gameplay seems fine but the boot time feels slow. 20-30s to boot. I've read that boot should be <10s. Have tried reflashing using a different tool but same problem. Used this card for my GarlicOS on my 35XX and it was fine and quick to boot. Strange!
Another question: is it possible for controller configs to default to a saved profile? Each time I start my game up it resets to default.
I have on rg35xx-h, boot was around 10-10 seconds.
I have a CubeXX and MUOS takes about 20 seconds to boot I would say. I am using the generic no name SD card that came with the device though. Feels fine to me.
Cheers. Couldn't get the included sd card to boot but can be ready by my pc. Have bought a modern class 10? to replace my old 32GB SanDisk that I'm using. Hopefully improves things.
