Considering new car time
It is very tempting, as I still have a huge chunk of my redundancy payout left from previous job even after paying the mortgage off :D
This was the one I was looking at:
I do have a driveway for 4 cars outside my house, so a charger would easily work for me. Just don't see the point of it yet, not until full EV's are an absolute must.
Honestly, as someone who only bought an EV so I could continue using an EV leccy tariff (and also had a 440i as my previous car)...should've swapped to an EV earlier :cry:
They're not hard to live with at all
Barring the depreciation (which isn't excessive unless you buy new/nearly new), the overall cost of ownership works out cheaper over the lifetime of the car - at least in my case, so YMMV.
I could understand that if you were driving a 911 or something, but you're looking at very standard 'white goods' type cars, an EV will drive a lot better and be miles cheaper to run than all of them.
But if you really don't want one then fair enough but do so knowing the facts
cvt, per Marshalls add, seem an acquired taste, versus a manual or auto/paddle box (mazda 3 say) to conserve petrol fun, along with japanese reliability;
can see depreciation on EV's transferring to petrol cars soon with the ev range/charge rate/insurance cost, stigma reducing with new ev's
so, a cross-over point where putting a chunk of money into a very new petrol is unwise - so hang onto existing car
Maybe chancellor will throw in a sweetener too on public ev chargers, even though that can be parity with petrol cost.
Hmm good spot, had no idea what that was. Just did a bit of research, basically belts instead of gears. Not keen on that idea.
OP got the sack from his WFH. He's now doing a 70 mile round commute.
70miles x 200 working days = 14k annual commute mileage
Jebus, that is 100% BEV territory I should read as well. :D
EDIT: 14k miles at 7ppkWh = £326 or less 3mpkWH.
CVT has a bad rap but reality is a bit more mixed, I've not encountered one which doesn't have some degree of intrusive whine though, though largely it doesn't bother me and/or I can just stick some music on to drown it out. You get used to the rubber band power response and the way revs don't work like in a manual car pretty quickly and/or some vehicles with hybrid type setups it can be minimised but it doesn't tend to be great if you are doing a lot of distance in like 20 zones, etc. underway it is usually pretty smooth and efficient though.
To be honest it wouldn't be my first choice though I'd probably take it over manual these days.
