Intel Core Ultra 9 285k 'Arrow Lake' Discussion/News ("15th gen") on LGA-1851
Quick question: I think I remember someone here testing the power consumption of a 285k and a 9950x system for one day (or something like that) each. How were the results for this?
I've used both the 285K and 9950X3D, and I have had both CPUs over 200W, depending on the state of tune.
Battlefield tends to be a tough game for leveraging the capabilities of 3D cache - while it gives big boosts in relatively mundane conditions when things become more chaotic it struggles to provide a benefit, ultimately for the smoothest performance in chaotic large scale action a mixture of frequency and core count wins out.
I've always found the Frostbite engine to be very RAM sensitive and loves bandwidth. It's often a better RAM / Cache test than the likes of Karhu etc...
In its default configuration (i.e without the user.cfg tweaks), it will use up to 28 cores if I remember correctly, which you can see by loading some of the console stats.
I can't remember if this has been posted: https://chipsandcheese.com/p/examining-intels-arrow-lake-at-the
As it highlights where the errors are with Arrow Lake, it does all boil down to the interconnect speeds and L3 cache speed. This is also where the Intel 200S Boost will aid the ARL CPUs, as it clocks the NGU and D2D to a ratio of 32, which brings quite a good uplift in performance while paired with RAM, which keeps the values under 1.4 on the VDD/Q
Did you measure the average power consumption across the whole day for each one?
The issue with most of the readily available power meters is nearly all of them are calibrated* at 50% of the maximum power rating and at 220-230 volts, while most of the UK is well over 245v. My supply is 246~ for instance, so right of the bat at 1840watts the meters 2% accuracy is more like 14% and the further away from 1840 (50% max) watts you measure the less accurate the reading.
Tried the Corsair HX1500i with direct motherboard connection and it actually shows about 15-20 watts higher than the wall power meter. I don't know what to trust now. It seems like the PSU reading should be more accurate, shouldn't it?
Depends a bit on the wall power meter - they vary from reasonably accurate to not at all accurate and some average over quite a long time period compared to the PSU reading which is often instantaneous.
Arrow Lake refresh (disappointing clock speed bump only) delayed to 2026, will probably launch just a few months before Nova Lake.
Surprised to note a new BIOS release for my Z890 board....
  1. Checksum : 93C5
  2. Improve memory compatibility
  3. Support V-Color new generation OLED memory
  4. Introduce Ultra Turbo Mode, a feature based on Intel® 200S Boost and enhances even greater gaming and general performance with a pre-configured overclocking profile built by GIGABYTE.Feature and support details please refer: https://www.gigabyte.com/Press/News/2300
  5. Based on Intel MR3* ingredients and support Intel® 200S Boost, a feature designed to boost gaming performance with a pre-configured overclocking profile built by Intel.Limitations and Warranty Disclaimers details please refer: https://www.gigabyte.com/Press/News/2271
* MR3 details:
- uCode version m_82_c0662_00000118
- MRC version 2.10.4.0
- CSME version 19.0.5.1992v2
- GOP version 1064
- RST VMD version 20.1.6.5864
Not brave enough to pit it against the 3d variant for gaming then!
The 265K is currently £280 vs £270 for the Ryzen 9700X.
"bUt its grEat valUe in AdoBe AfTereFfeCts" So what? if that mattered you would have to remind me, you wouldn't have to keep making blogs about how good your mid range CPU's are in productivity, We know.... We don't care, if we are doing productivity we are not buying mid range CPU's, we want them for gaming and they are too expensive for what they are in that, stop fooling yourself, you cannot command a premium for these chips because they bench a bit faster in Adobe Software.
Oh wont someone please buy my CPU's.... sure, happy too, if you can make it make sense to me, i'm not paying a premium for them, i don't care about E-Cores, they are getting turned off its a CPU for gaming.
Had around 10 hours on BF6 now across both the 9800X3D and the 265k system, it really is noticeable now 'smoother' the game feels on the 265k.
Playing at 1440p 300hz or 4k 240hz (depending on which monitor I fancy) and the 9800X3D has higher peak FPS but after 30/40 minutes it just feels like I'm dragging my mouse through mud. 265k doesn't get near the peak numbers of the 9800X3D but it has much less drops, feels snappier and I don't get that weird 'mouse mud' feeling.
Though it shouldn't affect the 9800X3D especially on more modern OSes BF3/4 hated core parking and even Windows 10 (11 has a different thread director) it can be a bit funky with that game engine if cores are parking which the game sporadically uses. As before there are things you can do with USB device power management to potentially fix issues related to that an input response though again not sure if it is the issue here.
Are you using Intel Boost and have you enabled gaming mode in the Bios?
Yeah, I'm having a bit of a look to see what I can do to help make it feel a bit more responsive. It's odd, it's absolutely golden on the 9800X3D system for the first 30 minutes or so - but as soon as I go back to the menu and search for another game it just feels like it suddenly takes this big step back.
I'll check a few more things out. The only annoyance is that my systems are set up relatively easily for me to swap between them - but I only have one 5070Ti which I have to move between both...!
Yeah, I'm on 200S Boost but haven't enabled game mode. From memory game mode doesn't tend to help with all games, only certain titles.
200S Boost will increase the VDD/Q up to a maximum value of 1.40 and increase the NGU and D2D to a ratio of 32, which greatly improves performance.
I'm curious why HUB didn't use it in the round of performance testing, as it will bring a noticeable uplift in performance but I guess they are hardware unboxed, which are load and go specialists.
This made me laugh in BF6 at the frame rate with Frame Gen:
